Help me plz ! Just started to build Jeep Wrangler SCX 10 with Falken-design. I'm new to this rc-hobby. But have trouble with the front end. Plz look at the pic's. I'm getting frustrated now. Someone get me tips about this issue ? In advance, BIG thx's guys. PS. Hope this is the right forum to post. Pic's : picload.org | img_20160529_140105.jpg picload.org | img_20160529_135302.jpg |
Not letting me see pics from my phone. Can you go into detail the issue your having? Copied and pasted to see. Are the top links on the bottom and bottom on the top? If try swapping them back around and see what happens. Did you try swapping the links back around to see if that helped? Looks like the top ones are slightly longer that the bottoms. Could just be the pic though. Also when adjusting them. The bottom links will set your wheel base for the most part and the top one will adjust the angle of the drive shafts. Just what I've learned building mine. |
Re: Help me plz ! Quote:
Re: Help me plz ! I'm assuming you swapped the front 3 link to a 4 link using parts on the part trees, so if thats the case what you did is used links that are way too long for it pushing your axle forward on it's axis slightly as well as affecting the caster which is your steering angle. You can make some shorter upper links with stuff from the hardware store and get everything back into spec "thumbsup" |
Re: Help me plz ! Looks like you used lower links on top, try switching them |
Re: Help me plz ! That'll push his wheelbase out even more. Just needs shorter uppers. |
Re: Help me plz ! the upper link SHOULD be shorter compared to the lower links on a rubicon the lower links are 115mm |
