07-25-2016, 05:57 PM | #1 |
Rock Stacker Join Date: Jun 2016 Location: portland
| holmes hobbies dual mini esc calibration
I am trying to figure out how to calibrate my hh dual mini esc's. I have everything all wired up and the hh instructions are a little confusing to me. I have the hh dual mini esc's wired together with a cc bec to the battery, the bec is then plugged into the battery port on a flysky 3 channel rx, I then have my esc signal leads ran into the rx with the red power wire removed from both esc's, two hh torque master motors are mounted and connected, and finally a 3s lipo to power the system. my confusion comes from connecting power during the calibration and programming process. The hh directions say that if using dual esc's they can't have battery power wires connected. without the battery power wire connected how do you power the system. I have been messing around with the system trying to get it running is there a way to re set anything I may have set by mistake or does it not matter when i do the calibration process correctly. And it would help if any tips are made very straight forward as I don't understand all the little things that may be assumed people just should know. I am still learning and some things make perfect sense and others not quite so much. Thanks
07-25-2016, 06:40 PM | #2 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: holmes hobbies dual mini esc calibration
Do you have a HH rx bypass? If so running a bec, you actually need the red wires hooked up because that gives power to the rx. You need to calibrate each esc, so plug one esc into rx, hook up battery (while holding full throttle) to calibrate it. Then unplug it, and do the same to the other esc. Then plug both esc into rx and you should be good to go. If you need to make any changes in the esc, hook it up to castle link.
07-25-2016, 07:04 PM | #3 |
I wanna be Dave Join Date: Dec 2006 Location: here
I'd use the BEC to power servo only.. At least have 1 red wire from br- minis go to rx to power the receiver... from what I remember you should calibrate 1 esc at a time... using channel 2.... so with BEC not in receiver plug front ESC with red wire into ch 2 and calibrate. Unplug front ESC and repeat with rear ESC In ch 2. After plug rear esc into you copycat ch on rx and front in ch 2 with at least 1 red wire from the HH br- minis in receiver for power.. IMO using BEC to power rx isn't correct way to power servo.. It can be done that way though. Last edited by tapped-out; 07-25-2016 at 07:13 PM. |
07-26-2016, 02:09 PM | #4 | |
Rock Stacker Join Date: Jun 2016 Location: Beaverton
| Re: holmes hobbies dual mini esc calibration Quote:
07-26-2016, 03:01 PM | #5 | |
Just see if they boot up without any fiddling. If the throttle isn't smooth, you can program the throttle endpoints on one ESC at a time by unplugging one from the radio. Isolating the power was an easy method that was written into the instructions before we made the Dual mini controller package. | |
07-26-2016, 11:40 PM | #6 | |
Not familiar with your radio my guess would be your 3rd ch is copycat/mirroring you 2nd ch throttle... But I'd listen to John first. | |
11-30-2016, 07:15 PM | #7 | |
11-30-2016, 07:52 PM | #8 |
Plug everything in like your about to go drive it, then calibrate it. If they both work then your good to go. But if one esc isn't working then you need to unplug both throttle channels and which ever isnt working, plug it into 2nd channel and calibrate it. If it works, then plug everything back in like normal and your good to go.
08-22-2017, 04:58 AM | #9 | |
Newbie Join Date: Aug 2016 Location: Chelsea
holmes hobbies dual mini esc calibration - Similar Threads | ||||
holmes hobbies torque master mini dual esc | blazerking | Electronics | 6 | 03-15-2015 06:57 AM |
Holmes BR mini dual calibration trouble | cyborgx | Electronics | 11 | 08-08-2014 03:09 PM |
