08-25-2016, 08:19 PM | #1 |
Rock Crawler Join Date: Sep 2015 Location: Lake Stevens
| SSD versus Vanquish SLW hubs
Does anyone know which Vanquish hub is the closest match to the stock hub on SSD stamped steel 2.2 beadlocks? I need to increase the offset on my front wheels, but don't know which Vanquish hubs to buy -- they only seem to list the width increments, but not the actual dimensions. Can figure out what to do of I know where I'm starting since I know how much the offsetneeds to change. Sent from my iPhone using Tapatalk |
08-25-2016, 08:21 PM | #2 |
Newbie Join Date: Aug 2016 Location: Miami
| Re: SSD versus Vanquish SLW hubs
Try the smallest, that's what I used and it seems like a close match theyre the 225 i believe , why do you need to widen it Btw? Sent from my SM-G386T1 using Tapatalk |
08-25-2016, 09:44 PM | #3 |
Thank you. Would be great if they all published mechanical drawings, but obvious why they don't. I have a SCX10 G6 with the Vanquish stage 1 kit. Wider hexes for the front axle worked with the stock tires, but now I put on 2.2 RC4WD mudslingers, which are wider -- so the conflict between the tires and the steering knuckles is back, mostly with the drag link rod end. I tried adding spacers between the hex and the hubs. Almost works, but the overlap between the hexes and the hub is getting pretty small. So wider hubs seemed like a better fix. Sent from my iPhone using Tapatalk |
08-25-2016, 09:51 PM | #4 |
Really impressed by the SSD wheels, btw. Look awesome, super easy to mount, and they seem to grip the tire really well. Also a great price. Mudslingers also sweet on the SCX10 and they're roughly the same od as stock tires, so they fit without using a lift kit. Sent from my iPhone using Tapatalk |
08-26-2016, 05:27 PM | #5 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
I think they are closer to .350.
08-26-2016, 05:36 PM | #6 |
Thanks. So safe bet is to start with the .350 dimensions and add the extra. Sent from my iPhone using Tapatalk |
08-26-2016, 05:36 PM | #7 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
By eye, its seems like then SSD hubs are probably between 250 and 300. The SLWs are in 1/8" increments IIRC. So if you need to go wider, Id start at 350 and go from there.
08-26-2016, 05:37 PM | #8 |
Nice. Thank you Sent from my iPhone using Tapatalk |
08-26-2016, 05:58 PM | #9 |
Buy a set of Shift hubs. You can customize your width with them and they fit SLW wheels. They are sold by a vendor here.
08-26-2016, 06:05 PM | #10 |
Must be: Presenting Shifts, Lightweight n' Flexible Offset Hubs They look pretty sweet. Sent from my iPhone using Tapatalk |
08-26-2016, 06:45 PM | #11 | |
| Re: SSD versus Vanquish SLW hubs Quote:
09-02-2016, 09:52 PM | #12 |
Thank you!
SSD versus Vanquish SLW hubs - Similar Threads | ||||
PSA: Vanquish SLW hubs use different screws than Axial SLW hubs | fyrstormer | Tires and Wheels | 2 | 04-29-2015 07:06 PM |
Vanquish slw hubs | 2013maverick | RC4WD Trail Finder 2 | 0 | 09-08-2014 01:52 PM |
