08-26-2016, 02:41 PM | #1 |
Newbie Join Date: Aug 2016 Location: Denver
| Axial 20t, Ae-5: which 3s lipo?
I have a stock axial wraith spawn with exception of a 14t pinion. I want to go 3s, and not sure what to get. The axial motor doesn't list any specs.
08-26-2016, 03:23 PM | #2 |
| Re: Axial 20t, Ae-5: which 3s lipo?
Get any one you like basically....i usually run geforce 2200-4000mah 3s lipos from value hobby.com. Anywhere from 30-60c.....
08-26-2016, 03:53 PM | #3 |
Thanks! I know the MAH rating is basically the capacity similar to NIMH, how does the C rating play into compatibility?
08-26-2016, 05:03 PM | #4 |
Rock Stacker Join Date: Jan 2016 Location: goldsboro
from what i understand that is a discharge rate,don't want a low c rating.it will over work the battery.
08-27-2016, 01:02 PM | #5 |
C rating has no effect on compatability.... crawlers can use lower C ratings if they are using normal brushed motors and lower rated brushless... high output brushless, you would need to pay more attention to the C rating if I recall correctly... probably 99% of crawlers and trail trucks would be fine with 25C or above...like I said, I keep mine in the 30-60 range... i like to think of it as watering with a 5/8 inch garden hose as compared to a 4 inch fire hose.... as long as your ESC/motor doesnt try to pull more amps out of your battery at a rate that it can deliver you will have no issues, when it tries to pull the amps at a rate your battery cant sustain, then you risk destroying the battery at the least and the entire rig at the worst (lipo battery fire) |
08-28-2016, 03:37 PM | #6 |
RCC Addict Join Date: Jun 2016 Location: Germany
Capacity multiplied by the c Rating divided by 1000, say max amp the lipo can develope. For example 3000 mAh 25c = max 75 Amp. If your Motor esc Combo needs more than this, the lipo could not deliver the requiered Amp. Hope that helps. sent by magic_yeti |
Axial 20t, Ae-5: which 3s lipo? - Similar Threads | ||||
how long will the stock Axial 20T motor last, running on 3S LiPo? | ussprinceton2004 | Axial Wraith | 6 | 02-13-2012 03:16 PM |
