11-21-2016, 06:55 AM | #1 |
Newbie Join Date: Jan 2014 Location: Ohio
| Xtra speed axle shafts on wraith?
Hi, I just picked up a used wraith that had xtra speed aluminum axles, but bot the front axle shafts are snapped. Does anyone know if this uses the same shafts as a stock ar60 wraith axle? It also has a broken hub on one wheel, it is a plastic beadlock and says method, will other hubs fit or should i look for a certain brand? If i get those two things fixed and a new rx/tx I will be super excited. I only gave $350 for two great condition rtr wraiths and this one which i hope i can get on the trail for under $100 |
11-21-2016, 07:09 AM | #2 |
| Re: Xtra speed axle shafts on wraith?
If you have multiple wraith then pull an axle shaft from one to test on the other. You need an slw hub from VP or I'd recommend shift hubs from lattice innovations. (pm BC-Brian here for best price)
Xtra speed axle shafts on wraith? - Similar Threads | ||||
Xtra speed "steel" SCX10 axle housing for everest 10 | Smokin' Joe | Redcat Crawlers | 9 | 12-24-2017 11:53 AM |
Xtra speed aluminium axle | Johan_Eriksson | Axial SCX-10 | 0 | 11-12-2016 01:37 PM |
Xtra Speed Steering | Fozzy73 | Axial Wraith | 13 | 08-22-2015 06:33 AM |
Xtra Speed Wheels? | Dodgevanman | Tires and Wheels | 0 | 04-28-2015 08:29 PM |
xtra speed rc | roughneck | General Crawlers | 6 | 04-06-2014 09:17 PM |
