12-15-2016, 02:47 PM | #21 | |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
| Re: Complete newbie needing advise Quote:
Probably the biggest question I have is can you solder? If you can most of those don't matter because you solder the plugs yourself. If you can't get a cheap iron and learn how, you'll thank yourself later. Here's the iron I used for like 10 years: TowerHobbies.com | Hobbico Soldering Iron 60 Watt But to answer your questions more specifically. Both the Sidewinder and BLE pro have 4mm female bullet plugs from the factory so you can spring for the motor leads and just plug it up the motor directly so it's super easy to put together (no soldering required). Brushed Motor Leads - Straight - Wiring & Wiring Accessories - Electronics & Wiring You want a standard rotation motor. 0* of timing is fine, and the matched pair thing doesn't apply to your situation. That's for crawlers that use two motors. I would also be tempted to have Holmes install an XT60 plug on the esc. That's what all the Chinese batteries use (yellow plugs). | |
Complete newbie needing advise - Similar Threads | ||||
Newbie needing Experience | kiwi68 | Newbie General | 5 | 08-21-2015 04:26 AM |
Newbie needing help | Sime111 | Electronics | 1 | 05-13-2014 05:53 PM |
East TN newbie needing help! | LMallette | Axial SCX-10 | 1 | 12-31-2013 10:40 AM |
newbie needing help | scarecrow | General Scale Talk | 5 | 04-17-2013 12:21 PM |
Newbie here needing some help | Rhino8123 | Newbie General | 29 | 04-28-2008 09:26 PM |
