Underdrive gear help.. I have built a set of ar60s for my maverick scout, installed 43/13 underdrive gear in the rear axle but I am unsure if I should use the gasket(?) that the stock gear has beetwen the gear and diff. Help a newbie pleaseee... |
Re: Underdrive gear help.. If you are using the stock locker then yes you need the gasket, aftermarket locker, no |
Re: Underdrive gear help.. Thanks for the reply! I have assembled it without the gasket.. fixed it already and it's "crawl after work" for me today! |
