06-21-2017, 12:09 PM | #1 |
Rock Stacker Join Date: Jun 2017 Location: Ganado
| Barrage battery
Would it be a problem if I install a speed pack 2400mah 8.4v 7-cell ni-mh battery into my ecx barrage? Or well it burnout the motor?
06-21-2017, 07:34 PM | #2 |
| Re: Barrage battery
If you don't get an answer here, PM hillbillyrc, he's a Barrage guru
06-21-2017, 11:51 PM | #3 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: Barrage battery
Specs for the esc in the barrage. This is the Dynamite WP 60A FWD/REV Brushed Electronic Speed Control. This ESC is built to allow the user to operate it in many "wet conditions," including puddles, creeks, wet grass, snow and even rain. Features: 2-3S LiPo compatible 5-9 cell NiMH compatible Removable mounting tabs Crawler Mode Small footprint for mounting flexibility LiPo safety cutoff Specifications: Type: Brushed Constant/Peak: 60A/360A Resistance: 0.0008 Ohms Function: Forward/Brake/Reverse, Forward/Brake, Forward/Reverse (Crawler Mode) Vehicle Type: 1/10 on-road and off-road, 1/10 rock crawler Operation: Proportional forward, proportional reverse with braking delay, Crawler Mode Battery Type/Input Voltage: 2-3 Cell LiPo/LiFe, 5-9 Cell NiMH/NiCd Motor Type: 540/550 size closed endbell motors: 2S LiPo down to 8T; 3S LiPo down to 13T BEC Output: 5V/2A Overload Protection: Thermal Dimensions: 35.6x34x18mm (1.40x1.34x0.71in) Weight: 40g (1.41 oz) with wires Battery connector: EC3 Connector Motor connector: 3.5mm Tamiya-style bullet Note: While waterproof, this component has not been designed to be immersed in water for long periods of time and should NOT be treated like a submarine. Hope this answers your question. And if by chance it the motor burns up (mine did with the stock battery and the high stock spur/pinion ratio) you can get better motors like taxxas 380 motor and team brood makes nice ones too (little more money but worth it). Pick up a 12t-13t 48 pitch pinion for 1/16-1/18 scale it should help keep motor temps down. |
06-22-2017, 06:43 AM | #4 |
| Re: Barrage battery
O ok thanks hillbillyrc, was waiting for ur response.
06-22-2017, 12:54 PM | #5 |
| Re: Barrage battery
No problem I try to help when I can.
10-23-2018, 05:17 PM | #6 |
Newbie Join Date: Oct 2015 Location: Mangilao, Guam
| Re: Barrage battery
Hillbilly can i run a 3s lipo with the stock motor? Battery: Gens ace 5000mah 50c 3s lipo Sent from my EVA-AL00 using Tapatalk |
10-23-2018, 05:36 PM | #7 |
| Re: Barrage battery
I run a 3s with my barrage doomsday right now, no problems
10-23-2018, 05:37 PM | #8 |
| Re: Barrage battery |
10-23-2018, 05:52 PM | #9 |
| Re: Barrage battery
Just to clarify even with the stock 390 motor? Sent from my EVA-AL00 using Tapatalk |
10-24-2018, 07:24 AM | #10 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
10-24-2018, 01:23 PM | #11 |
Quarry Creeper Join Date: Jun 2015 Location: France
| Re: Barrage battery
The weight will kill the spools before the voltage burns the motor ...
11-05-2018, 02:31 PM | #12 |
Quarry Creeper Join Date: Jan 2008 Location: Eagle Mountain, Utah
| Re: Barrage battery
You will have way better performance and longer runtimes from a cheap 2000mah 2 cell lipo than a 2400mah 7 cell nimh....
Barrage battery - Similar Threads | ||||
Barrage upgrade | Darrell | General Crawlers | 3 | 06-13-2017 06:59 PM |
The Barrage H3 | 88gmchog | General Scale Talk | 21 | 03-05-2017 09:06 AM |
ECX barrage | Cpyonker | General Crawlers | 7 | 12-21-2016 09:18 PM |
