10-03-2017, 02:19 PM | #1 |
Quarry Creeper Join Date: Jul 2017 Location: Sweden
| What wires for Tekin - Mamba X connection?
This really is a newbie question, please bear with me. I have started to gather parts for a Yeti build and today I got my Tekin Pro4 HD. Nice! But how do I connect it to my Mamba X? I thought wires would be included with either the motor, or with the ESC, but no. What kind of wires and connectors do I need to buy? I am placing an order with Tower Hobbies within the next couple of days and hope to get this in as well, but do not really know what to look for. Could I use any kind of electrical wire? What gauge will I need? Bullet connectors? Links would be most appreciated, it's a jungle out there... |
10-04-2017, 03:14 AM | #2 | |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: What wires for Tekin - Mamba X connection? Quote:
castle has a set of 3 4mm connectors http://www.castlecreations.com/en/co...cc-bullets-4mm Gesendet von meinem T1-A21L mit Tapatalk | |
10-04-2017, 03:19 AM | #3 |
Thanks! And then I just solder the wires directly to the motor? Maybe some heat shrink over the motor connections as well?
10-04-2017, 06:05 AM | #4 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
you don't need heat-shrink over the motor connections. They're spaced far enough apart not to have issues. Plus if you heat shrink over it, you'll just have that much more work when you unsolder in the future. I would recommend that you put some heat-shrink over the bullet connectors though. On a crawler you'll probably never have an issue, but on other vehicles a hard crash could bend them together, or if you use it with a different ESC that has the bullets at the end of a wire, you'll want some isolation. |
10-04-2017, 12:03 PM | #5 |
Thanks a lot! 4mm bullet connectors and 14AWG silicone wire is to be ordered.
10-04-2017, 12:13 PM | #6 |
14 AWG will probably be ok in a crawler, but it seems a bit small to me. For something like a Tekin Pro4 HD, I'd use 12 AWG.
10-05-2017, 05:36 AM | #7 |
Do you think 12AWG will fit the bullets? Specification says they are for 13-16AWG.
10-05-2017, 06:59 AM | #8 |
It should. Worst case is you can cut away a few strands until it fits. As long as you solder it well, it will be fine.
10-05-2017, 09:33 AM | #9 |
Thanks again, I really appreciate your help! 12AWG it is.
10-05-2017, 11:29 AM | #10 |
as we are at soldering. easiesed way to solder bullets. drill a 4mm hole in a peace of wood, so the small hole on the side of the bullet is clear. than put bullet in and use a solder tip that fits the hole. fill the bullet half way with solder and then stick the wire in the fluid solder. i managed 10 awg in 4mm bullets so 12awg should fit. Gesendet von meinem T1-A21L mit Tapatalk |
10-09-2017, 12:39 PM | #11 | |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
10-09-2017, 01:21 PM | #12 |
| Re: What wires for Tekin - Mamba X connection? |
What wires for Tekin - Mamba X connection? - Similar Threads | ||||
Water? Dust? Broken wires? Bad Connection? Help please! | XcrawlerkidX | Electronics | 12 | 10-17-2012 07:12 PM |
Tekin FXR wire connection issues. | americanricer87 | Electronics | 8 | 07-17-2012 12:08 PM |
Connection wires?? | demonoid369 | Chit Chat | 6 | 09-21-2011 11:19 PM |
Mamba Max / Crawlmaster Connection Question. | wshipley | Electronics | 3 | 08-05-2007 02:34 PM |
Mamba to Crawlmaster connection questions | Mr_Freeze | Electronics | 12 | 07-27-2007 01:31 AM |
