Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Shock advice
Old 11-17-2017, 09:54 PM   #1
Default Shock advice
My son has a Deadbolt and he really wants King shocks. I have seen different sizes. His crawler is all stock right now. May want to go with 2.2 tires (not sure if that matters) What size should I get? Any help is appreciated. Thanks!
Lilfuzz is offline   Reply With Quote
Old 11-17-2017, 10:07 PM   #2
Stay in 1.9 better. Here is the good King you need in your deadbolt https://www.amainhobbies.com/rc4wd-k...zd0063/p410261
These are the newest King in bigger OD. Bigger always the best
Last edited by THX_138; 11-21-2017 at 11:20 PM. Reason: Merge, posts a minute apart
Teng is offline   Reply With Quote
Old 11-17-2017, 10:20 PM   #3
Default Re: Shock advice
Thank you for quick reply. So 100 mm. I know it's a different topic but why are 1.9 better?
Old 11-18-2017, 09:27 AM   #4
He's going to have wheels that are too big for the vehicle if he upsizes to 2.2, more specifically too big for the wheelwells.
Think of it this way - it's roughly a 10th scale truck, 1.9" is equal to running 19" wheels. 2.2" would be 22" wheels - or that "Mall Crawler" look...
The tire would likely end up being too tall and fouling the fenders when cycling through the suspension and steering.
If he wants a taller tire, there are plenty of different tires available that fit on a 1.9" wheel.
Many of them are quite tall - the stock Axial Trepadors that come on the Deadbolt are 4.6".
Most popular replacements are about 4.75" (Pro-Line TSL SX Super Swamper XL & Hyrax, PitBull Growler AT/Extra Scale, RC4WD Mickey Thompson Baja Claw TTC, JConcepts Scorpios, etc)
The Pro-Line Interco Boggers are 5.4"!
durok is offline   Reply With Quote
Old 11-18-2017, 09:53 AM   #5
Thanks for the tire info! That helps a lot. I think he just wants bigger (taller) tires. I will look into some taller ones you listed that will fit on current size rim
Old 11-20-2017, 10:34 AM   #6
Natedog's Avatar
Shocks I'd stay close to stock 90mm, it will crawl much better than with longer 100mm shocks.
Old 11-20-2017, 01:52 PM   #7
DO the boggers come any shorter than 5.4 or is that it
Big Sky Crawler is offline   Reply With Quote
Old 11-20-2017, 02:06 PM   #8
Natedog's Avatar
Not currently, 5.4" is it.
https://www.prolineracing.com/rock-crawling-tires
Old 11-20-2017, 03:02 PM   #9
Proline only offers them in 5.4" for 1.9"s (just picked up a set!)... but if he's got his heart set on Boggers, RC4WD offers Boggers in 4.79" RC4WD Interco Super Swamper 1.9" TSL/Bogger Scale Tire that should fit the bill, and they have (used to have?) their own unlicensed version called "Mud Slingers" in 3.66" Mud Slingers 1.9" Tires both for 1.9" wheels.
TheLetterJ is offline   Reply With Quote
Shock advice - Similar Threads
Shock & spring advice for GCM shock hoops. Ca. Off Roader Vaterra Twin Hammers 11 01-04-2016 12:17 PM
Shock Advice? TuffNStuff Axial SCX-10 30 11-08-2013 02:42 PM
Need some shock advice 2-shot Newbie General 2 04-06-2012 08:32 PM
need some shock advice mattstang Axial AX-10 Scorpion 5 11-05-2009 09:07 PM
Shock advice WranglerV8 Losi Mini-Rock Crawler 5 01-07-2009 03:39 PM
