11-26-2017, 10:57 PM | #21 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: Axial bomber servo destruction
I also have a ProModeler (v5 470 oz). I have yet to find any situation where it hasn't had enough power, and that's on 6.0v. i've had mine for about 43km on BC trails, so far zero problems, not even when driving through deep puddles. always ice cold when i get home. you get candy and a bottle sleeve in the box, for free. (that's the real reason i bought the servo )
11-27-2017, 12:35 AM | #22 |
RCC Addict Join Date: Jun 2016 Location: Germany
Don't forget to set the endpoints correctotherwise you will kill the servo again |
11-27-2017, 06:44 AM | #23 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: Axial bomber servo destruction |
11-28-2017, 09:42 AM | #24 |
Newbie Join Date: Nov 2017 Location: CO
after reading this thread I hope my 7955tg holds up. But ive put another one through hell on a 6s monster truck, i was thinking it would work ok in the rr10.
12-01-2017, 05:32 AM | #25 |
Noticed over at the UCFab page that they have been running a MKS X8-Series HBL380 in their hand-welded U4 racer, and in their modified Bomber. Pricey! (Around $190) But, nice spec sheet: SKU MKS-HBL380 Dead Band 0.0008ms (Default) Control System +Pulse Width Control Working Frequence 1520μs / 333hz Operating Voltage 3.5 ~ 8.4 Volts Operating Temperature Range -10 to + 60 Degree C Operating Speed (6V) 0.114 sec/60° degrees at no load Operating Speed (7.4V) 0.092 sec/60° degrees at no load Operating Speed (8.4V) 0.082 sec/60° degrees at no load Stall Torque (6V) 430.51 oz/in (31 kg/cm) Stall Torque (7.4V) 541.61 oz/in (39 kg/cm) Stall Torque (8.4V) 569.38 oz/in (41 kg/cm) Motor Type Brushless Motor Potentiometer Drive Indirect Drive Bearing Type 12x8 mm Double bearings Gear Type Chrome-Titanium alloy gear Connector Wire Length 24.0 cm (9.4 in) Dimensions 40 x 20 x 38.5 mm Weight 73 g https://www.amainhobbies.com/mks-x8-...kaAiklEALw_wcB Last edited by durok; 12-01-2017 at 05:34 AM. |
Tags |
axial, axial bomber, bomber rr10, help noob, servo help |
Axial bomber servo destruction - Similar Threads | ||||
Axial Bomber chassis mount servo? | trascall10 | Axial RR10 Bomber | 4 | 05-28-2017 03:10 PM |
Axial Bomber Servo Question... | GEWarEagle | Newbie General | 4 | 03-25-2017 10:26 AM |
what caused the destruction of my servo? | dieselfuel | Electronics | 3 | 04-09-2012 03:37 PM |
