12-13-2017, 01:30 PM | #1 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Brushless motor shaft wiggling?
Hello. I recently acquired a slash 4x4 with a sidewinder brushless set up. I can’t get a pinion to stick for longer than a matter of seconds so I’m wondering if the motor shaft is the culprit. Here’s a video of the motor in slow mo. Assuming this isn’t normal, how do I fix it? https://youtu.be/gL4K7oHxMhQ |
12-13-2017, 01:33 PM | #2 |
| Re: Brushless motor shaft wiggling?
That motor is junk! Time for a new one. The vibrations from the shot bearings are definitely enough to rattle a pinion gear loose. |
12-13-2017, 01:37 PM | #3 |
RCC Addict Join Date: Jun 2016 Location: Germany
I would check the bearings, looks like broken bearings. regarding the loose pinion did you loctide the set screw? hope that helps |
12-13-2017, 01:49 PM | #4 |
Bummer! Guessing it’s not rebuildable? Any idea on reasonable replacements that work with the same esc? Had lock tite on two of the 3 that flew off and it was on the flat part of the shaft. I was about to slap on the 5mm adapter and another pinion to see if that would help but wanted to get some opinions on the motor beforehand Learned a couple things, bearings were toast. Also, it was a chinese knock off, not even a real castle. Got a 2nd legit castle in now and running again. Thanks for the help! Last edited by THX_138; 02-13-2018 at 10:04 PM. |
12-16-2017, 06:49 PM | #5 |
Funny thing is even the real castle motors are made in China. At least the 3800, 4600, and 5700 I have are. They've all got tons of hours on the original bearings and they are still snug. Stay away from those goofy 5mm reducer sleeves. They all seem to add run out to the pinion gear when you tighten the grub screw. |
12-18-2017, 04:00 PM | #6 | |||
| Re: Brushless motor shaft wiggling? Quote:
And agreed. | |||
12-19-2017, 12:46 AM | #7 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
Wow. That bearing is completely trashed. I have seriously never seen a motor bearing that badly worn. It looks like the BBs are all gone.
12-19-2017, 07:14 AM | #8 |
We could tell it was a knock off when we took it apart to rebuild and compared it to another castle 3800. Shorter can and the inside was a bit different. Taking the word of a friend that’s been working on these for years there though, he was helping me check it out. As you all have guessed, the bearings were toast and falling apart when we got it open. Since replacing the motor I put a mamba x in and it’s running great now. I had to do some cutting on the body to keep it on the ground during speed runs. Here’s a little video from a quick run last night with a 3s 20c lipo. https://splice.gopro.com/v?id=7Awr9r Last edited by Topher Builds; 12-19-2017 at 07:48 AM. |
Brushless motor shaft wiggling? - Similar Threads | ||||
Diff cases wiggling inside bulkheads on Summit | fyrstormer | Traxxas Crawlers | 24 | 10-05-2015 10:01 PM |
How do i change brushless shaft direction? | Tzi | Electronics | 5 | 09-12-2007 07:44 PM |
Pinions for brushless motors 4mm shaft | setecastronomy | General Crawlers | 2 | 09-04-2007 07:32 AM |
