Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Gmade gom build motor died
Old 01-15-2018, 10:29 AM   #1
Default Gmade gom build motor died
Hey guys i bought a lot made gmade gom off a guy close by who didn't have money to finish. I put an esc, receiver. Everything else was ready to go. It's a sweet build he put alot of wraith parts cuz they are aluminium and proline shocks I was excited and after 5 min of running motor smoked and died. It still has power to everything but the motor. Any suggestions?? I'm new to this so anything helps. Thanks for ur time
Sent from my SM-G930T using Tapatalk
bradendavis4 is offline   Reply With Quote
Old 01-15-2018, 11:06 AM   #2
Default Re: Gmade gom build motor died
Put a new motor in but check the gearing as well to ensure its suitable.
Whilst the motor is out also turn the truck upside down and see if there's much resistance when turning the wheels. This should rule out other areas that could cause the motor to work harder than you'd want.
Sent from my Pixel using Tapatalk
Crawler Cads is offline   Reply With Quote
Old 01-15-2018, 02:13 PM   #3
The GOM can be a pig with alignment sometimes if you have a 550 in there. Is it a 540 or a 550...my 550 didnt fit great as I didnt dremel out some plastic. Sounds like the pinion could have been too tight for the spur. Did he build the gearbox correctly...I assume you can work through 2nd 1st and DIG.
thewildblue77 is offline   Reply With Quote
Old 01-15-2018, 02:30 PM   #4
I only could get one gear to work when I had it going. Where should I start?
Old 01-15-2018, 03:07 PM   #5
Take it apart...then check servo movement and look at your end points. Do you have a 3 position 3rd channel switch?
Sent from my SM-G935F using Tapatalk
Old 01-15-2018, 04:03 PM   #6
Yes 3 channel, when I had it.begore i could see the post try to go and if i pushed it the front would lock in but nothing on rear
Old 01-16-2018, 12:34 AM   #7
When you do strip it, put a washer in as a spacer to allow the slider to move freely...this will help with changes. Also the dig spring may need setting up. Have a look in the gmade section here...there is a long thread on the GOM.
Gmade gom build motor died - Similar Threads
Soze's GMADE GOM GR01 Build soze G-Made Crawlers 69 08-20-2021 12:45 AM
Coming soon .....GMADE GOM-GR1 Rock Buggy big1717 G-Made Crawlers 951 05-12-2019 02:43 PM
Bishop's RC Gmade GOM ULTRA4-truck Pisepise G-Made Crawlers 18 06-13-2018 11:33 PM
NEW BLOG - Gmade GOM Rock Buggy Kit Build – Part 1 RPP Hobby RPP Hobby 0 01-03-2018 11:40 AM
Gmade Gom crawling on the backyard course HumboldtEF Videos! 2 11-03-2017 09:39 AM
