02-26-2018, 07:46 PM | #1 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| Threadlock ???
Sorry for the dumb question, but , does it have to be a RC threadlock,or any threadlock will work metal to metal , or am I wrong ? Sorry and thanks again .
02-26-2018, 08:01 PM | #2 |
I joined the Band! Join Date: Feb 2018 Location: Everywhere
| Re: Threadlock ???
Blue loctite Sent from my iPhone using Tapatalk |
02-26-2018, 08:05 PM | #3 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
| Re: Threadlock ???
Any threadlocker should work metal to metal. You might want to look at "purple" as it is specifically for thread sizes smaller than 1/4" dia. that may need occasional adjustment. I used to use "blue" all the time but from what I can understand, purple does the same job on small fasteners that blue does on the larger diameters. Use "red" only if you NEVER want to remove the fastener. Generally requires heat to be able to loosen a bolt installed with red threadlocker. A relatively unknown threadlocker is "green". It has a specific use and is comparable to red in that it needs heat to remove the fastener. |
02-26-2018, 08:07 PM | #4 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: Threadlock ???
If you use something too strong like red Loctite then you may not be able to remove it without breaking something.
02-26-2018, 08:22 PM | #5 |
| Re: Threadlock ???
So, this should be fine ? https://rover.ebay.com/rover/0/0/0?m...2F351979880692 |
02-26-2018, 08:47 PM | #6 |
| Re: Threadlock ??? |
02-26-2018, 08:57 PM | #7 | |
| Re: Threadlock ??? Quote:
Green is penetrating, its designed to use on already made threads. Sent from my iPhone using Tapatalk | |
02-27-2018, 06:26 AM | #8 |
Pebble Pounder Join Date: May 2016 Location: France
| Re: Threadlock ???
I bought this cheap one on ebay to see if there's a true difference with known brands, I'll report if it ever show up https://www.ebay.com/itm/K-0242-50ml...72.m2749.l2649 |
Threadlock ??? - Similar Threads | ||||
Where to get this type of threadlock? | maverick67 | Tools, and Procedures | 18 | 07-13-2017 04:37 PM |
Axial and threadlock | AngelowDoom | General Scale Talk | 0 | 12-30-2014 12:51 PM |
Threadlock on pinion screw? | doc.hamilton | Newbie General | 4 | 03-04-2013 08:37 PM |
Red Threadlock | ROCKST*R | General Crawlers | 4 | 02-16-2013 09:06 AM |
Removing ThreadLock | rctoyguy | Tools, and Procedures | 15 | 10-22-2010 05:06 PM |
