Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Link pivot balls
Old 02-28-2018, 06:40 AM   #1
Default Link pivot balls
I am replacing some of the pivot balls on my scx10ii honcho with brass pivot balls. I was curious what is the best method you have found to "press" these new pivots in?
prondzy is offline   Reply With Quote
Old 02-28-2018, 06:50 AM   #2
Default Re: Link pivot balls
Some shock tools have a little pin to press in or out the ball ends.
I use one from hot racing.
Sent from my Nexus 6 using Tapatalk
Jboucher is offline   Reply With Quote
Old 02-28-2018, 06:57 AM   #3
Thanks i will have to look into those!
Old 02-28-2018, 07:07 AM   #4
I use a socket that is bigger then the hole but not the rod it self and push on it.
Skickat från min iPhone med Tapatalk
Johan_Eriksson is offline   Reply With Quote
Old 02-28-2018, 07:29 AM   #5
Moderator
JatoTheRipper's Avatar
Yep, a shock pliers is a must. It helps to install and remove pivot balls as well as holding shock shafts without damaging them when building shocks. I use the Protek.
JatoTheRipper is online now   Reply With Quote
Old 02-28-2018, 12:24 PM   #6
Looks like the way to go then i guess
Old 02-28-2018, 04:29 PM   #7
I just ordered a set, thanks guys!
Link pivot balls - Similar Threads
Why are axial pivot balls garbage? NitroDarwin General Crawlers 24 03-13-2018 11:35 PM
Stock Link Pivot Balls 864runner Losi Micro-Rock Crawler 10 08-31-2017 09:26 AM
Pivot balls acidtherory420 Axial Yeti 4 11-22-2016 09:25 PM
NEW pivot balls from AXIAL pro mod steve Axial Yeti XL 9 04-08-2015 09:29 PM
plastic pivot balls pro mod steve Axial Yeti XL 9 04-04-2015 09:44 PM
