BULLY 2 MOA Battery/motor/pinion gear Please share your Battery/motor/pinion gear configuration. Example: lipo3S-m45T-p20T (it could be mine :mrgreen:) ..and knuckle weights: half front - no rear |
Re: BULLY 2 MOA Battery/motor/pinion gear Quote:
Wouldn't p20T give you too much speed for controlled crawling? I've got my throttle set at 40% due to speed and ordered p11T. Maybe p12T is a better choice, but 20!!!! How does it crawl? |
Re: BULLY 2 MOA Battery/motor/pinion gear 450 Mah Battery 16T Homles Hobbies Motor 12T Pinion Not sure of my exact knuckle weight, But probably around 2oz per side, nothing on the rear. |
