07-03-2018, 03:10 PM | #1 |
Newbie Join Date: Jul 2018 Location: Nor Cal
| Steering horn binding with traxxas lift
As the title says, I just installed the traxxas long arm lift kit for my trx4 and my steering horn is binding on the track bar. At rest on level ground I have maybe 2mm of clearance between the two. More clearance when I turn hard to the right, and even less when I turn to the left. I have a Savox sw-0231mg servo and an axial aluminum clamper steering horn. I took the horn off and I have a little bit of clearance with the track bar. Maybe a stock plastic horn would fit? Unfortunately I binned mine when the stock servo died. I have a few photos of this in this gallery. https://imgur.com/a/2C68pPg Can anyone make a recommendation on what I should get to fix this issue? Swap back to a factory plastic steering horn? Swap for a factory/shorter steering servo? Last edited by Foxtrot121; 07-03-2018 at 03:51 PM. |
07-03-2018, 03:18 PM | #2 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: Steering horn binding with traxxas lift
Would using the closer hole on the arm and shortening it work?
07-03-2018, 03:53 PM | #3 | |
| Re: Steering horn binding with traxxas lift Quote:
Maybe I need to find a horn that is skinnier than what I have now... https://www.amazon.com/gp/product/B0...8538acd1d8c2ac https://www.amazon.com/GPM-Traxxas-D...B2SP8AZPZK8CD7 Like one of those^. I just don't want to go back to a stock steering servo for the sake of a lift. | |
07-03-2018, 04:10 PM | #4 |
RCC Addict Join Date: Jun 2016 Location: Germany
Normally i would say mount the servo on the other side, but it looks like it is not possible on the mount you use. On the other hand the savöx 0231 is a nice servo but don't have enough torque for a trex, the savöx 0231 is higher from the mounting ears to the out spline which is causing your problem. as i could see on your pics. |
07-03-2018, 04:29 PM | #5 | |
07-03-2018, 05:47 PM | #6 |
I may be wrong here but I thought the servo mounts on top of the servo mount and not below it on the TRX-4. I'll double check that when I get home later. Oh and if you have your pictures hosted you can easily insert them here. EDIT: Yes the servo mounts above/on top of the servo mount and not below it. Last edited by HumboldtEF; 07-03-2018 at 06:32 PM. |
07-03-2018, 06:48 PM | #7 | |
07-03-2018, 06:55 PM | #8 |
Oh, sorry I didnt realize that had a different mount with the lift kit. I suppose regardless it needs to be raised up somehow, I was thinking you might be able to use the old mount but you need the panhard mount thats built into the new one. I would try raising the servo you have before resorting to buying a new low profile one. EDIT: You might also get more eyes on this thread if it were posted or moved to the TRX-4 section http://www.rccrawler.com/forum/traxxas-trx-4/ Last edited by HumboldtEF; 07-03-2018 at 07:12 PM. |
07-03-2018, 07:15 PM | #9 | |
07-04-2018, 12:31 AM | #10 | |
My First steering servo upgrade was a powerhd 20kg waterproof, with all the axle weight i changed it to a Holmes hv500 v2 direct powered from my lipo using a HH Bypass. In the trx-4 section you can find several threads regarding servos and in the electronic section as well. What the newest cheap servo hotness? Whats the Best 100$ Servo possible servo choices... and a thread regarding the hi lift kit TRX-4 Long Arm Lift Kit Send by my Pixel 2 XL with Tapatalk Last edited by magic_yeti; 07-04-2018 at 12:37 AM. | |
Steering horn binding with traxxas lift - Similar Threads | ||||
Steering Bind with traxxas lift kit | Foxtrot121 | Traxxas TRX-4 | 0 | 07-03-2018 02:16 PM |
Driveshaft binding with lift | Joseph molnar | General Crawlers | 3 | 01-06-2018 10:55 PM |
Serious steering binding | wouterb | Axial Wraith | 10 | 06-03-2015 03:59 AM |
Steering Binding | Mac28 | G-Made Crawlers | 2 | 06-21-2011 10:01 PM |
High-Lift Mods (steering servo, track bar and body lift) | thefordmccord | 1.9 Scale Rigs | 5 | 07-17-2009 11:41 PM |
