07-10-2018, 10:35 AM | #21 | |
| Re: When to add a BEC? Quote:
This isn't directed at anybody in particular, but it's a general observation. It's funny that people insist on cutting off ESC switches because they don't want a component that can fail, but they'll happily add a more complicated BEC which is another component that can fail... | |
07-10-2018, 11:30 AM | #22 | |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
Since I'm cheap, and I like the challenge of finding new and innovative ways of being cheap, I often use ESCs that don't have as robust of a voltage regulator as I'd like, so running an equally cheap external regulator is a pretty common thing for me. I also find these types of regulators to be extremely valuable whenever I'm using any external accessories, since I tend to DIY my own accessories that were originally intended for other applications... mainly because they're cheaper that way. | |
07-11-2018, 05:50 AM | #23 |
Quarry Creeper Join Date: Feb 2016 Location: canada
Heres one for yea how do u know its not enough lmao im running a mamaba x on 3s using the jx 46kg servo, 4" light bar, full light kit, the 2850kv motor and all extra i have is a cheapy yeah racing glitch buster plugged in knock on wood no issues yet Sent from my LG-M703 using Tapatalk |
07-11-2018, 08:52 AM | #24 |
The Mamba X has a pretty decent internal regulator, and unless that servo is bound up, it's not going to draw a lot of current most of the time. Likewise, that 4" light bar is probably only sucking 1/2 Amp or less.
07-11-2018, 09:59 AM | #25 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
Two CC 10amps failed in 1 year wiping out electronics. I will never build a rig again with a BEC, unless it is being used to step down for something stupid like leds. I have found that there is plenty of solid electronics to run off internal BEC or straight batteries. | |
07-11-2018, 11:12 AM | #26 | |
Exactly. If the ESC has a shit internal BEC I just won't buy it anymore. That limits me to a select few choices, but those select few are high quality. | |
When to add a BEC? - Similar Threads | ||||
BEC | Castle Creations CC Bec 10A 6S Switching Regulator | le varan | Axial Yeti | 8 | 06-02-2015 12:08 PM |
Add a BEC to RTR? | Pfreddy | Axial Yeti | 6 | 03-07-2015 10:05 AM |
Should I add a BEC to a wraith on 2s? | strap624 | Electronics | 11 | 10-12-2011 08:30 AM |
do I need to add a BEC if I add a second servo? | 5wattchamp | Electronics | 4 | 04-29-2009 09:54 PM |
