07-03-2018, 03:21 PM | #1 |
Newbie Join Date: Jun 2018 Location: Raleigh
| When to add a BEC?
I've got the Hobbywing QuickRun WP Brushed Crawler ESC, that has an internal BEC. Is this good enough or should I also install another BEC? I ask because I see a lot of talk about making sure you have a BEC and wonder if what I have is enough.
07-03-2018, 03:47 PM | #2 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: When to add a BEC? Quote:
BEC's are a PIA.(although my heyok is 3 years old and never fails) I have had two CC bec blow in a year wiping out two servos and two servo winches. The HW1080 at 7.4vs is plenty to run all but the most power hungry 7.4v servo. | |
07-03-2018, 04:41 PM | #3 |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
| Re: When to add a BEC? I'm assuming you have the 1080. You probably should have listed which servo you are running to best answer this question. If you want more than 7.4v, you will need something else to power your servo (battery or external BEC). Otherwise you should be ok with the 1080, unless (as stated by Ditchrat) you are running a very power hungry servo.
07-04-2018, 12:42 PM | #4 |
get it , install it and be done
07-04-2018, 12:55 PM | #5 |
It all depends on what you are running. Not sure which flavor of QuickRun you have, but the specs for the first one that comes up says it has a 3A BEC. If your servo is rated less than 200oz, or you are not running other things like a winch or lots of LEDs you should be fine. If you are running a higher torque servo and/or winch, you will want to go with more amperage to power all of that stuff, otherwise you will get glitching. The best option is to get an ESC that has a strong BEC, like the Mamba X (8A), if that is not an option, then go with an adjustable external BEC like the CC 10A BEC. The CC BEC allows you to adjust voltage using a FieldLink card or CastleLink. You can get them waterproofed, or not waterproofed. I save a little money and waterproof my own with conformal coating. |
07-04-2018, 01:17 PM | #6 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
The Quicrun 1080 happily handles my 7955TG and some 6 LEDs (nothing fancy, regular white 5mm) at 7.4V. Adding a winch soon so maaaaybe I'll think about adding an external BEC. Maybe not. |
07-04-2018, 02:28 PM | #7 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: When to add a BEC? The time to install a BEC is about 15 minutes after you open the box, before you power anything up. Best $20 you can spend in RC.
07-06-2018, 06:11 AM | #8 |
Quarry Creeper Join Date: Jan 2008 Location: Eagle Mountain, Utah
The only reason to get a BEC, is if your ESC's build in BEC cant handle the load. You will know it cant handle the load because it will drop voltage far enough that the radio will cut out for a moment. If you arent having any issues, there is no reason to add an external BEC....
07-06-2018, 06:18 AM | #9 | |
The days of external BEC's being better then internal BEC's is gone. Certain internal BEC's are just as good as external. After spending $20 on CC BEC's twice to have it wipe out $120.00 in servos, twice it is the absolute worst $20.00 I spent twice. | |
07-06-2018, 06:58 AM | #10 |
If you have to run an external BEC with modern electronics than you're doing something wrong or you chose an ESC with a garbage internal BEC.
07-06-2018, 07:07 AM | #11 | |
The only real issue is HV receivers. I've been pushing 7.4v through the flysky receivers with no ill effects. | |
07-06-2018, 07:13 AM | #12 | |
You bring up a good point about the receivers. It's about time the radio manufacturers bring those into current times with the ability to handle more voltage. | |
07-06-2018, 01:28 PM | #13 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
My Tactic TR325 (comes with the TTX 300 that a lot of Axials have) ran 7.5v from my Mamba X without complaint, and I've been running it at 7.4 from my WP 1080 for a long time with no problems. Sent from my Nexus 5 using Tapatalk |
07-06-2018, 04:23 PM | #14 | |
That's not nearly as good as the HobbyWing QuicRun 1080 ESC, switchable voltage from 6v to 7.4v, 3A BEC... I found this statement on a FlySky retailer site: "The new FS-GR3F receiver can now accept up to 8.4 volts of power to muscle the new high voltage servos." This is what comes standard with the GT3-C transmitter. As a comparison, the Futaba 3PV with the R203GF receiver (non-telemetry) shows Operating Voltage: 4.8 to 7.4V, same as their R304SB telemetry option. If you seek out the "sold separately" R304SBE telemetry receiver, it shows a Usable Voltage: 3.5-8.4V. Of course, the FlySky tx/rx sells for half the price of a Futaba 3PV, and their receivers are about $8 - that "higher voltage" Futaba telemetry receiver is a cool $50 by itself! Amazing what buying "budget" electronics can get you in some cases... | |
07-09-2018, 02:57 PM | #15 |
I am running the 1080 Brushed Crawling ESC. The servo I'm using is the Savox SW-0230MG Waterproof Metal Gear Digital Servo (High Voltage). Other accessories that I have installed are a Warn winch and a light kit from MyTrickRC which includes headlights, turn signals, front and rear bumper lights, and light bar and a few spotlights. The receiver I'm using is the Futaba R204GF-E. I haven't run into any issues as of yet. Just curious because I've seen a lot of discussions about BEC's. Still getting my feet wet in this hobby, especially with crawlers, so a lot of this is brand new to me. Appreciate the feedback from everyone. |
07-09-2018, 05:35 PM | #16 | |
07-10-2018, 03:59 AM | #17 |
Pebble Pounder Join Date: Jan 2017 Location: @scaleobsession on instagram
I run a HW1080 and a pro modeler 470 at 7.4V on my scx10.2 and the same setup in my trail finder, except at 6.0V and it all works very nicely.
07-10-2018, 05:50 AM | #18 | |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
07-10-2018, 09:54 AM | #19 |
| Re: When to add a BEC? Doesn't that mean you have to bypass the servo around the receiver then?
07-10-2018, 10:28 AM | #20 |
| Re: When to add a BEC? |
When to add a BEC? - Similar Threads | ||||
BEC | Castle Creations CC Bec 10A 6S Switching Regulator | le varan | Axial Yeti | 8 | 06-02-2015 12:08 PM |
Add a BEC to RTR? | Pfreddy | Axial Yeti | 6 | 03-07-2015 10:05 AM |
Should I add a BEC to a wraith on 2s? | strap624 | Electronics | 11 | 10-12-2011 08:30 AM |
do I need to add a BEC if I add a second servo? | 5wattchamp | Electronics | 4 | 04-29-2009 09:54 PM |
