02-26-2019, 08:28 PM | #1 |
Newbie Join Date: Feb 2019 Location: Sophia
| Bomber binding/getting hot
I recently got a RTR RR10 bomber and I'm having issues with binding and motor getting really hot. I have the Axial 20T brushed motor with a Hobbywing 1080 esc, Proline tsl xl tires and proline plastic beadlocks and a Power HD LW25mg servo and I run a 5000MaH 20c 2s lipo battery, and stock gearing. It's pretty slow and runs fine on flat, but when I try crawling stuff it tends to bind up or I have to pull the throttle all the way down to get it to barely move and the motor is getting really hot (I'm assuming from binding) Any suggestions on what I can do to change this?
02-26-2019, 09:56 PM | #2 | |
| Re: Bomber binding/getting hot Quote:
start with trying to roll it with the battery disconnected and see how it rolls, with a 20 axial motor is should roll somewhat easily, if it doesnt, disconnect the drive shafts and try again, if it now rolls freely then you have an issue with the motor, trans or possibly spur/pinion mesh. hook up the drive shafts and remove the motor or just the pinion see how it does...if it still rolls easy, most likely you have a motor that is burned up or in the process of going out.. | |
02-26-2019, 11:41 PM | #3 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
It is a crappy motor, so maybe if you were expecting a not crappy motor you are now confused |
02-27-2019, 06:54 AM | #4 |
Now that you mention it. Ever since I got it, it won’t roll more than a half a turn before locking up without the battery in it
Bomber binding/getting hot - Similar Threads | ||||
RR10 - 35T cool but 27T hot...how 'hot' can a brushed get and live? | CoolRunning | Electronics | 9 | 03-04-2017 06:06 AM |
Bomber Kit Rear Diff Binding | OkinawaCrawler | Axial RR10 Bomber | 7 | 01-30-2017 03:31 PM |
Hot racing shock cap binding | Dionisi | Axial Yeti XL | 0 | 05-29-2015 09:21 AM |
Totally hot, hot, hot Melons inside! | hvydty1 | Chit Chat | 6 | 06-03-2009 08:48 PM |
Hot Racing MOA's Binding up.. | Laker67 | General Crawlers | 11 | 05-09-2009 11:07 PM |
