02-15-2019, 01:51 PM | #1 |
Newbie Join Date: Jan 2019 Location: middle Tn
| trx4 sport motor
If i put a new motor in my sport do i have to use a reverse rotation? I just installed a hobbywing 1080 esc. Is there a brushed motor that will give me more power? Thanks for any info
02-15-2019, 02:12 PM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: trx4 sport motor
Yes you need reverse direction. if u have a 0 timing brushed motor just swap the wires. A good and cheap replacement is the HH trailmaster 550 21T, should be better than a new titan. My stock motor still last on me, so the HH is on the shelf and not tested, but was recommended a few times U can find more info in the trx section http://www.rccrawler.com/forum/traxxas-trx-4/ |
02-15-2019, 04:47 PM | #3 |
To be honest, the HW1080 works very well with the stock Titan 550 21t motor. As stated above the HH Trailmaster Sport 550 21t is a nice replacement (not an upgrade) for the stock motor with nearly identical performance. Assuming any motor you use is set at zero timing there should be no difference between forward and reverse.
02-18-2019, 10:56 AM | #4 |
Pebble Pounder Join Date: Feb 2012 Location: Boomer
I have a hh trailmaster motor in my sport. There all non adjustable on the timing, so if your motor runs backwards when you hook it up, just swap the motor wires.. good to go. Ps there really good motors
02-18-2019, 02:33 PM | #5 |
Pebble Pounder Join Date: Oct 2018 Location: boise
What kinda power are you looking for? You on 3s? My Sport is geared down 15/45 and has plenty of power with stock electronics.
trx4 sport motor - Similar Threads | ||||
TRX4 Sport Build | puravida | Traxxas Crawlers | 6 | 05-02-2019 01:01 PM |
Trx4 sport motor | pyroM!KE | Traxxas TRX-4 | 4 | 02-06-2019 07:23 PM |
TRX4 sport truggy | awoodman | Videos! | 0 | 01-28-2019 07:54 PM |
Trx4 kit or trx4 sport | mebeknob | Newbie General | 10 | 09-26-2018 10:38 PM |
