02-17-2019, 10:55 AM | #1 |
Newbie Join Date: Jan 2019 Location: US
| 3mm Mod 1 Pinion: Rock Rey + Holmes Hobbies Motor
Where can I find one?? I have a Holmes 2700kv Sensored motor I'm all excited to put to use with a Mamba X in my Rock Rey, but I can't find a 3mm (or 1/ Mod 1 pinion... Do I need to use a reducer sleeve? With how common the Holmes Motors are around here, I'm confused as to how this has not been discussed or mentioned anywhere... Am I missing something? Thanks in advance for the help!! Sent from my Pixel 3 XL using Tapatalk Last edited by Stanleybb50; 02-17-2019 at 11:07 AM. |
02-17-2019, 01:00 PM | #2 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: 3mm Mod 1 Pinion: Rock Rey + Holmes Hobbies Motor
A reducer bushing isn't ideal, but it will work and does seem to be your only option. Sent from my SM-G960W using Tapatalk |
02-17-2019, 01:54 PM | #3 |
| Re: 3mm Mod 1 Pinion: Rock Rey + Holmes Hobbies Motor |
02-17-2019, 02:12 PM | #4 |
I finally found this discontinued item. Will give it a whirl. For now I'll just install the ESC with the current motor until that arrives. https://rover.ebay.com/rover/0/0/0?m...2F202440515052 Sent from my Pixel 3 XL using Tapatalk |
02-17-2019, 06:00 PM | #5 |
I just put her back together with a Holmes Hobby TrailMaster ESC (based on the Mamba Max I believe the name is?) with the stock motor and it's already like a different rig. Still cogs, but not nearly as bad, and is very smooth throughout. Can't wait to get the sensored motor in it! **As I type this on my phone I realized I didn't hook up the sensor wire for the motor when the pinion comes in so I'm gonna have to rip the rig/body apart to change the motor due only to that.... Sent from my Pixel 3 XL using Tapatalk Last edited by Stanleybb50; 02-17-2019 at 06:11 PM. |
02-20-2019, 09:18 PM | #6 |
Just following up that I got the sleeve but a didn't feel comfortable (and it stripped on me ultimately as well). So I got a cheap (but awesome) motor with a 5mm shaft from rc juice (ego shipped faster than Amazon order to door btw (no joke). Anyway - got it all installed and it's flipping awesome from just little test runs. Sent from my Pixel 3 XL using Tapatalk |
02-21-2019, 06:29 AM | #7 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
I have the exact same motor in my Yeti and I love it.
02-22-2019, 07:37 PM | #8 |
Quarry Creeper Join Date: Nov 2018 Location: Oakley
I just ran into a similar issue on my rey. I wanted to put in an HH puller pro 540 BL 2700k for the slow speed crawling. I had seen a few people had put this motor in so i just bought it without looking. Anyways, i found these: ECX Pinion Gear 9T/12T x 3mm Mod 1 https://www.amazon.com/dp/B00IJE9MJO..._vflCCbW6VK7ZH I dont know how they will be but i like that its a 9T. Lowest i could find was 10T before, but since its gunna be a trail rig im kinda glad about 9T. |
03-05-2019, 09:14 PM | #9 | |
| 3mm Mod 1 Pinion: Rock Rey + Holmes Hobbies Motor Quote:
I got these in today and they seem decent. They fit the 3mm shaft on my puller pro nicely with no slop. I havent put the motor in yet because i need to modify the mount plate to work with the 9T. | |
3mm Mod 1 Pinion: Rock Rey + Holmes Hobbies Motor - Similar Threads | ||||
Help an old timer pick a Motor/ESC for Rock Rey ?? | crunky | Newbie General | 1 | 01-26-2019 07:31 AM |
Cheap brushless motor / ESC for Rock Rey | MrBlank | Electronics | 16 | 08-01-2018 10:43 AM |
Losi Baja Rey and Rock Rey Aluminum Hop-ups - In Stock! | RPP Hobby | RPP Hobby | 4 | 03-22-2017 04:30 PM |
