Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Traxass TRX 4 Sport with new steering servo
Old 02-22-2019, 05:42 AM   #1
Question Traxass TRX 4 Sport with new steering servo
I just installed a Savox 1210 SG steering servo. The only mods I've made to the truck so far are 2.2" wheels/tires. The servo seems to work ok but I get a buzzing noise from the receiver. I can fiddle with the steering trim on the controller & it will stop buzzing. As soon as I touch the steering wheel it starts buzzing again. I'm still running the stock electronics. Would an external BEC cure this? Or did I screw something up or is there another answer? Thanks
smittykid is offline   Reply With Quote
Old 02-22-2019, 05:48 AM   #2
Default Re: Traxass TRX 4 Sport with new steering servo
Nah its a savox thing they all buzz fomr what ive seen. I have the big 400oz of torque savox and that thing is so annoying compared to my jx servos
Sent from my LG-M703 using Tapatalk
jokersinsanity is offline   Reply With Quote
Old 02-22-2019, 06:46 AM   #3
Worry when your Savox stops buzzing...
Just make sure the servo is centered with the steering and that the end points are set correctly and you should be fine.
For the end points, at full throw on the steering input (TX) the steering should be driving into the stops just enough so that you here the servo protest a little bit (a little louder buzzing than normal).
Greatscott is offline   Reply With Quote
Old 02-22-2019, 08:29 AM   #4
Moderator
JatoTheRipper's Avatar
Funny! True, but funny!
Old 02-22-2019, 10:38 AM   #5
Also, before you install any BEC, your next upgrade should be the HW Quickrun WP1080 ESC.
Inspector86 is offline   Reply With Quote
Old 02-22-2019, 04:46 PM   #6
The buzzing is coming from the receiver - not the Savox servo.
Old 02-23-2019, 10:47 AM   #7
Sounds like you might need a BEC, but before you do that, unplug your servo and see if the buzzing is still there.
Sent from my SM-G960W using Tapatalk
MasteroFlego is offline   Reply With Quote
Old 02-23-2019, 11:47 AM   #8
What TX/RX are you using? There should be nothing in the RX to buzz...
Old 02-23-2019, 03:38 PM   #9
First of all, I want to apologize. After closer examination - it is in fact the Savox servo buzzing, not the receiver. And to answer the last question, I'm running the stock XL5 HV receiver.
Traxass TRX 4 Sport with new steering servo - Similar Threads
TRX-4 Sport Servo upgrade question: endpoints OKmon Newbie General 5 01-18-2019 10:18 AM
TRX-4 Sport 4RunnerKid Traxxas TRX-4 104 08-29-2018 08:59 PM
Traxxas trx 4 sport vs redcat gen 7 sport part 2! shenlonco Scale Videos! 0 08-03-2018 06:31 AM
Traxxas trx 4 sport vs redcat gen 7 sport! shenlonco Scale Videos! 0 07-23-2018 07:19 AM
Question about powering a TRX-4 steering servo upgrade. secondcircle Newbie General 4 01-05-2018 01:58 PM
