High clearance knuckles Do HCK give you more of a turning radius, or are they just for looks ? |
Re: High clearance knuckles That would likely depend on which vehicle you're asking about. |
Re: High clearance knuckles On my original scx10 rigs they did turn tighter as long as aI put in cvd's or universal joint axle shafts at the same time. This being said, if you use the high clearance knuckles, your steering link will need changed as the stock one will no longer work. |
Re: High clearance knuckles Quote:
Buy? You really need to start building your own links. You'll enjoy the flexibility. |
Sent from my LGMP450 using Tapatalk |
Re: High clearance knuckles What's a better choice the HR or Axial Hi clarence knuckles?https://uploads.tapatalk-cdn.com/201...4f4a0d4479.jpg Sent from my LGMP450 using Tapatalk |
Re: High clearance knuckles something else to think about if you have a axle mounted servo the servo link could interfear with the steering link if your running a chassie mounted servo it will play havic with your steering geomitry not a big deal but it will take a bit of tinkering to fix it |
Re: High clearance knuckles I thought these were just to move the track rod up. |
I have a chassis mount servo , how does the cms play havoc to the steering geometry, just because its in a different location? |
Sent from my SM-N950U using Tapatalk |
