Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: AX10 Deadbolt vs. SCX10 Body Holes
Old 03-06-2019, 06:58 PM   #1
Default AX10 Deadbolt vs. SCX10 Body Holes
I have an AX10 Deadbolt and want to put a factory prepainted SCX10 Deadbolt body on it. From what I understand, the front holes line up...but the rears do not. Is that right?
How far off are the mounts? I don't want to be making new holes that are too close to the existing holes as to compromise the body. (If that makes sense)
I know this is a noob question. I tried to find the answer I'm looking for...but I can't.
Do you know the answer to this question?
Thank you so much!!!
DarkBlack is offline   Reply With Quote
Old 03-06-2019, 07:08 PM   #2
Default Re: AX10 Deadbolt vs. SCX10 Body Holes
You are not going to compromise the body. Do what you have to do then patch the old holes.
If they are too close use some scrap lexan to make a backing plate. Or if you are lucky you can find some offset posts that will fit.
Ditchrat is offline   Reply With Quote
Old 03-06-2019, 07:28 PM   #3
Awesome! Thank you for the reply!!!
Another newbie question: Who makes offset posts that I might look at? (If I go that route)
I know the AX10 Deadbolt/Ridgecrest isn't the most popular thing out there...but I like it.
Old 03-08-2019, 10:31 AM   #4
Natedog's Avatar
As Ditchrat said, agreed. I was in the process of rebuilding and putting Deadbolt body on my SCX when I sold it all, it can be done.
IIRC Axial makes/made some little offset pieces that were for different bodies, came with my SCX10 kit.
Old 03-08-2019, 11:16 AM   #5
SCX10 has straight body posts, the scx10II has offset post. The Deadbolt body switches back and forth between the two.
So that gives you two pin options to start with. I do not know the AX10 mounting position so I can offer help.
However there are body mounts with screw holes on top instead of pin hole. You could screw a plate to them, and then mount pins to that plate to fit your AX10 mount positions.
Old 03-23-2019, 12:50 PM   #6
I have cut and drilled new holes to use scx10ll body mounts on my ax10 deadbolt to accept scx10 bodies. I believe I just used the offsets to make it work. I've also heated them up on other rigs when they are close to bend them over. Good news is that they are cheap. Mess them up and you can always get more
rb16sk8 is offline   Reply With Quote
Old 03-25-2019, 05:48 AM   #7
Moderator
You can make your own offset posts. Get a set of posts, and use a heat gun or a cigarette lighter to heat the posts a little bit. Once they get hot enough, you can bend them how you need.
Jim85IROC is offline   Reply With Quote
AX10 Deadbolt vs. SCX10 Body Holes - Similar Threads
longer body mounting holes on rear posts? Ax10 deadbolt Spence Axial AX10 2nd-gen 0 01-21-2018 08:27 PM
AX10 deadbolt body on SCX10 deadbolt BrianP Axial SCX-10 3 11-08-2015 04:51 PM
Deadbolt ax10 or scx10 MeanTT General Crawlers 4 04-23-2015 07:34 PM
Deadbolt AX10 Body on an SCX10? SCX10Dingo Axial SCX-10 7 02-28-2014 08:45 AM
