03-09-2019, 10:20 AM | #1 |
Newbie Join Date: Feb 2019 Location: Lincoln, NE
| VP Portals: Adding brass
Hi guys. Ok so I went big with my SCX10 II raw build and ordered up the VP portals. Gulp!!!! My question is: With the higher CG, what’s the best way to add brass to this setup? I know what options are out there, just not sure what will work with the portals. I’d like to stay away from wheel weights if possible. Thanks in advance for your suggestions!
03-09-2019, 10:38 AM | #2 | |
Quarry Creeper Join Date: Jun 2018 Location: CRG
| Re: VP Portals: Adding brass Quote:
03-09-2019, 02:15 PM | #3 |
I actually did get in on the sale elRayRay. Otherwise my wife would’ve kicked me out!! That’s a valid point regarding the added weight of the axles themselves. And I did invest in the OD gears for the front, as you suggested. I was concerned about turning the dang thing!! Lol I appreciate your input sir. If you’ve got any other suggestions or recommendations I’d love to hear ‘em. I’m about 20 years removed from RC (brand new to crawling), and things have changed just a bit! Thanks again! |
03-09-2019, 02:52 PM | #4 |
Not sure about knuckle weights, etc for the VP Portals. But, you could go with some brass Beef Patty wheel hexes/scale rotors and get some additional weight in a simple, cost effective way. (they're also available in Aluminum if you determine you just want to add a little bit more weight). Being right on the axle versus out on the perimeter of the wheel, they won't over-stress your drivetrain either. Plus side - they're good for scale points at comps as well. https://www.rpphobby.com/product_p/bt005hb.htm https://www.rpphobby.com/product_p/bt005ha.htm |
03-09-2019, 05:58 PM | #5 | ||
VP Portals: Adding brass - Similar Threads | ||||
Hot Racing Brass Knuckles and SSD Brass Weights compatibility | saddlesore | Axial SCX10 II | 5 | 07-15-2017 04:27 PM |
portals | Werock | Axial Wraith | 6 | 11-20-2016 12:48 PM |
Portals?? | demonoid369 | Axial Wraith | 3 | 08-17-2011 10:07 PM |
Anyone seen these portals before? | infanterene | Tamiya CR-01 | 18 | 06-23-2009 02:25 PM |
portals? | lIRATIl | Newbie General | 1 | 12-27-2007 07:05 PM |
