Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Ssd portal weights for trx4 sport?????
Old 03-14-2019, 06:54 PM   #1
Default Ssd portal weights for trx4 sport?????
Are the SSD portal weights for the trx-4 sport ever going to be in stock again? Iíve looked everywhere. The only place I found them NOT on back order is RCmart. The last time I started to buy something there I caught myself before I committed because the shipping was OUTRAGEOUS.
garage-boo is offline   Reply With Quote
Old 03-14-2019, 06:57 PM   #2
Default Re: Ssd portal weights for trx4 sport?????
Aren't they the same as any trx 4. I wasn't aware the sport had different portals.
Sent from my SM-G960F using Tapatalk
pieterv3814 is offline   Reply With Quote
Old 03-14-2019, 07:02 PM   #3
Yes they are the same as far as I know, just being a little overly descriptive
Old 03-14-2019, 07:03 PM   #4
The SSD 00198
Old 03-14-2019, 07:11 PM   #5
Ohhhh makes sense. I've seen the GPM ones in stock. But not the SSD ones
Old 03-14-2019, 09:45 PM   #6
Are the GPMís a good option? Iíve got some aftermarket beadlocks, so Iíve to watch clearance
Old 03-14-2019, 10:13 PM   #7
I haven't got any. But I've heard they're good
Old 03-14-2019, 10:16 PM   #8
Inspector86's Avatar
Just wait for the SSD portal weights to come back in stock you won't be disappointed.
Inspector86 is online now   Reply With Quote
Old 03-15-2019, 06:57 AM   #9
That’s my plan. I’ve just read too many positive comments on them to go any other route. I’ve also got a bowhouse lcg battery tray coming too. I can tell by what little crawling I’ve done so far I need some weight in the front end and as much weight as possible low.
Old 03-20-2019, 06:24 PM   #10
Thatís my plan. Iíve just read too many positive comments on them to go any other route. Iíve also got a bowhouse lcg battery tray coming too. I can tell by what little crawling Iíve done so far I need some weight in the front end and as much weight as possible low.
As if you needed more positivity for them, I love mine as well. SSD front portal weights and the Bowhouse LCG tray are pretty much the only weight tuning I've done to my Bronco and it feels infinitely more capable than stock, and I'm running 3s 5000 packs that take advantage of the bowhouse rear chassis brace relocation. I also have Gmade SR02 metal beadlock wheels adding some weight as well. Solid sidehiller and can climb like a goat although I haven't exactly measured the max degree of incline yet.
The SSD stuff is great because of the inoffensive color too.
jessedacri is offline   Reply With Quote
Ssd portal weights for trx4 sport????? - Similar Threads
Video - Inspecting TRX4 Portal axles BadBeard General Crawlers 2 01-22-2019 04:27 PM
Trx4 kit or trx4 sport mebeknob Newbie General 10 09-26-2018 10:38 PM
New SSD Brass Portal Weights SSD Traxxas TRX-4 19 01-25-2018 07:39 AM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
