03-19-2019, 07:35 PM | #41 | |
Newbie Join Date: Oct 2008 Location: Hamilton, Ontario, Canada
| Re: Axle Length Modification Possible Quote:
Hi Sorry bad eyes, wrong link in last post. In my VERY First entry here you replied with a link to a Tamiya Club build of a 4WD Sand Scorcher. It had a small front axle so that it would run 4WD. Anyone know what that was? George | |
03-23-2019, 03:27 PM | #42 |
Update I am going to go with the Tamiya sand scorcher front suspension. So now I am on a SLOW parts hunt through ebay and used sources as well. When ALL parts are collected then I will start my build with pictures of the build post here. If anyone has sources for the Tamiya Sand Scorcher front suspension, used would be a great start. I have the ebay source for the new parts, just trying to keep costs down. Thanks Again for your Support/Help George |
03-24-2019, 02:49 PM | #43 |
Hello Also forgot to ask. IS there a Small size motor /transmission that can work with my build, it has to be less than a 1/10 because space is tight! This car is NOT a rock climber OR a speeder. IT will be an average speed car. IT will be going from land to water and then back again and I would like the ability for it to be 4WD. Also I need a SMALL front gear box to drive the front wheels through the Sand scorcher front suspension. Is that possible? Can you post links to the parts so I can see them? Thanks Again for your help. George |
03-24-2019, 09:25 PM | #44 |
this rig has everything you need just use the sand scourcher suspention inplace of the stock front end any short course truck style or pan car parts will work http://www.ebay.com/itm/293018708027 heres my first thought to use this as a donor http://www.ebay.com/itm/361969590595 the twin hammers might work out better there a bit smaller than your average short course truck but they have a solid rear axle |
03-25-2019, 01:27 PM | #45 |
Hello I was just at a local toy show and in a open box was two partial chassis for sale, both were 4WD so I bought both at an INCREDIBLE price! I will try to take a picture of them to post here for BEST recommendation of which one to use. I do know that one is used on the Tamiya Hummer Army jeep and the smaller other one I have No clue. George |
Axle Length Modification Possible - Similar Threads | ||||
Modification questions! Axial rockrails and shock length | twisted concept | Tamiya CR-01 | 3 | 04-14-2012 06:48 AM |
[How To] RS10 BTA : Behind The Axle modification | Big Pitt | Redcat Crawlers | 15 | 03-27-2012 09:21 PM |
Axle shaft strength & modification quest | rckjeep | Tamiya TLT Crawlers | 10 | 12-12-2010 09:28 PM |
TXT-1 Axle Modification and Link Mounts | mavrim | Tamiya Txt-1 and Juggernaut | 34 | 06-16-2010 05:54 PM |
