04-11-2019, 06:34 AM | #1 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
| Hot Rod Crawler |
04-11-2019, 06:53 PM | #2 |
| Re: Hot Rod Crawler |
04-12-2019, 06:36 AM | #3 |
| Re: Hot Rod Crawler
Not much info there but thanks anyway ;)
04-12-2019, 03:14 PM | #4 |
| Re: Hot Rod Crawler
What do you want to know? Edit: er what would you like to know (attempting to sound more friendly than grumpy.) Last edited by Voodoobrew; 04-12-2019 at 03:31 PM. |
04-13-2019, 09:54 AM | #5 |
| Re: Hot Rod Crawler
well...first I didnt get it grumpy ;) second I like to know the material you used for the frame and on what 3d machine you printed it. I am new to all of this but your project certainly tempted me Is it a real MOA , what motors did you use and whats the time aproximately to print this thing? Loooots of questions I know----sorry for that cheers Andy |
04-13-2019, 10:49 AM | #6 |
| Re: Hot Rod Crawler
I printed this on a cheap maybe $150 er $250 anet a8 using Petg filament. The petg is kinda like a blend between abs which is hard to print an pla which is too brittle. The printing surface is 220mm x 220mm. The hotrod is not a MOA at all. My axial bomber is MOA, thay are both in my sig. The hotrod is basically all axial wraith running gear. Except the transmission output is extended on mine. Currently this runs on a 550 10t (2200kv) crawlmaster, hobbywing 1080, at 104:1 gear reduction. The print time if printed at 0.3mm about three 16 hour days. |
04-13-2019, 03:32 PM | #7 |
| Re: Hot Rod Crawler
thanks so much for your input!! I will be 3d printing soon and something like this is very high up on my list!
04-13-2019, 04:37 PM | #8 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
| Re: Hot Rod Crawler
I see this thing on Thingiverse all of the time. How does it crawl? Is there any video of it?
04-14-2019, 12:42 AM | #9 | |
| Re: Hot Rod Crawler Quote:
It has a 15 inch wheelbase and a pretty low center of gravity so it crawls pretty well, the center skid drags on a lot but it slides over pretty easily with the petg plastic. the main weakness is the cab, the plastic pillars for the front window dont like falling on granite, I have also busted the grill a few times flipping over backwards onto concrete. It crawls at least as good as my modified scx10II but each have places they don't and do excel at. But for for a first try I'm happy with it. Probably won't be doing much to it for a while though as I just started an accelerated nursing program. Last edited by Voodoobrew; 04-14-2019 at 01:40 AM. | |
Hot Rod Crawler - Similar Threads | ||||
Hot Rod | Husy | Large Scale Rigs | 16 | 09-22-2014 07:32 PM |
Scx Hot-Rod | Senior Latya | 1.9 Scale Rigs | 37 | 01-01-2013 05:50 PM |
Im going to be on Hot Rod TV! | willipmartinni | Chit Chat | 28 | 04-29-2012 12:21 AM |
