04-15-2019, 10:18 AM | #41 | |
| Re: Advice for a complicated setup? Quote:
Good luck with whatever chassis you choose. | |
04-15-2019, 10:55 AM | #42 | |
The number for RTR is around $450 and I'll exceed that slightly. But it's my belief that it is less expensive in the long run compared to modifying a kit or the RTR. The real value is in performance and durability at a lower price point as I've started from kits before and then replaced or improve parts for performance and durability. Different strokes for differnt folks. | |
04-15-2019, 05:24 PM | #43 |
Newbie Join Date: Apr 2019 Location: copiague
Okay So im thinking about either a Holmes Hobbies Puller Pro Stubby 2200KV or 3300KV with a Mamba X ESC or a Hobbywing AXE Pro 2300KV for Power. Suggestions on Either. Im leaning to the Mamba and Holmes 2200KV, but have Hobbywings in everything else and like them. I know they seemed to have some issues originally, but is the firmware fixing any of it? I dont think i need more than 2200KV and plan on using 3s, but if more is better im open to sugestions.
04-15-2019, 06:45 PM | #44 |
Quarry Creeper Join Date: Feb 2018 Location: East otis
One thing to think of, well 2, is how castle has adjustable drag brake (from transmitter) and throttle curve. I love hobbywing stuff, have them in my bashers, but once I used an esc with those 2 options i can't go back. Got spoiled. You might not need the adjustable drag brake if it's strictly comp crawler, but if you plan on some trails, it'll be a nice option to turn it down. Also, a higher kv motor geared down will give better throttle feel then a lower kv with the same top speed, so I would recommend the 3300kv. Sent from my SAMSUNG-SM-G920A using Tapatalk |
04-15-2019, 07:14 PM | #45 |
The adjustable drag brake on the radio is handy but it eats up a channe6on the receiver. Nothing wrong with the X & Holmes combo at all. |
04-15-2019, 07:42 PM | #46 |
Yeah, i already have all the channels used, but i ordered a Mamba X anyway. Hey White-Trash, does the Toyzuki guys normally take a long time to respond. I Sent a message about where to buy, and tried to join the group, but havent heard anything back from either yet. If it just takes a while im fine waiting. Just want to make sure i dont have to do anything else.
04-15-2019, 07:48 PM | #47 |
I sent a message to Ben directly, I suspect I'll hear back tonight.
04-15-2019, 07:50 PM | #48 |
Your the man.....
04-15-2019, 09:42 PM | #49 |
Since you have a open budget and like complicated stuff why not pick up a cheap flysky gt3c controller and hack it to run 8 channels then you could run the drag break and a winch and lights and a 2speed
04-16-2019, 07:39 AM | #50 |
I had a Flysky GT5 6 channel for a little while, but didnt like it. Im liking my MT-S at the moment so really just want to stay with the one controller. Im not too worried about the speed since i got a good motor esc combo. The drag brake is the one that i would like the most and i think i may try to split channel 3 with a y cable. I figure i would only really want the drag brake on mainly when my portal axles were locked. So i want to see if i can have it so they get adjusted at the same time, So axles locked, drag brake on. The lights and winch while nice, i just dont think i would use enough, and can always add them later.
04-16-2019, 07:42 AM | #51 |
Also, Im looking at using either 1.9 or 2.2 tires, not fully decided yet. But when I do decide, is that where i should start a new build thread? In the 1.9 or 2.2 forum, or should i start it somewhere else?
04-16-2019, 08:24 AM | #52 |
If you use a single servo to activate the lockers you'd only need that channel to be a 2 position switch so a y harness would activate the drag brake function easily. Put the build in the general tech section since it sounds like it'll kinda be all over the map. |
04-16-2019, 08:42 AM | #53 |
The larger tires push your center of gravity up same as your Portals will do. Probably stacking those two it might cost you. 2.2s might help if the rocks are extra jagged or your car is so heavy you need more surface area touching th rocks.
04-16-2019, 08:46 AM | #54 |
Yeah im actually leaning 1.9 anyway, just was looking at all options. I dont think i will ever need all that clearance, and dont want to have to add weight to keep it down for no reason.
04-16-2019, 06:30 PM | #55 |
White-trash sorry to bother you, but did you hear anything back from the toyzuki guys. I forgot to mention I'm louiekova on that site since it's a work account t I had.
04-16-2019, 09:31 PM | #56 |
Yea I talked to Ben past night, he's just busy. He is a 1 man shop, I'll rattle his cage again. I know there are a couple guys wanting to hand him money for a V3 at this moment.
04-17-2019, 08:07 AM | #57 |
Not a problem then, thanks for checking for me, ill just wait till he has some time.
04-18-2019, 03:09 PM | #58 |
Its starting to get real now, Just received My portal axles and Vanquish Dig unit. Also got my Holmes Puller Pro 3300KV and two savox servos for the dig and the axles. Heavy Duty transmission set for the SCX10 for the middle. I also decided to try the Dessert Lizard Internal Spring 90mm shocks for the build. ESC and some more stuff should be coming tomorrow. Now the hardest part, i just have to wait till i can buy the chassis and start on my build. Not usually a patient person as you can probably tell haha. Looks like its going to be fun. I have a screw kit coming along with some screws i had laying around. Any other suggestions for things i may need sooner rather than later for the build? |
04-19-2019, 01:00 PM | #59 |
The toyzuki bumpers and side skids are separate purchases.
04-19-2019, 02:34 PM | #60 |
Btw voodoobrew. Awesome 3d printed crawler I'm actually currently printing out a chassis from thingiverse to use and build all my parts for now, while I'm waiting for toyzuki. that someone designed. I have about 6 hour of prints left |
Advice for a complicated setup? - Similar Threads | ||||
Need some setup advice. | Hobbezco | Vaterra Ascender | 28 | 05-03-2017 11:21 AM |
Suspension Setup Advice CC01 | Drakken | Newbie General | 2 | 06-03-2015 01:20 AM |
need advice, setup on budget 200$ | nitrooxide | Axial AX-10 Scorpion | 20 | 05-20-2012 12:58 AM |
noobie looking for setup advice... | crudeau | Venom Creeper | 2 | 11-10-2011 04:43 PM |
steering setup advice | GEARSCIENCE | EnRoute Berg | 8 | 10-05-2009 01:50 PM |
