Trx4 sport with OD/UD GEARS I’ve got about a 7.5lb trx4 sport with a HH 550 21 turn motor and 45/15t gears. I’m thinking about putting in OD/UD gears. Am I thinking right? Would this be a good setup. I mainly like crawling and am zero percent concerned about speed. |
Re: Trx4 sport with OD/UD GEARS The OD/UD setup is a personal preference kind of thing. I don't see any need for this unless you are competing and for trail running it is not a good setup. Unless you have a specific need I would not waste the money. Also, to be honest, I would change your gearing to 45/9. Your 15t pinion is going to make the motor work harder and run hotter. |
Re: Trx4 sport with OD/UD GEARS 10-4. I’m just trying to make this rig the best I can. I was kicking around picking up another rig, but decided I’m just going to stick with this one and max it out! |
Re: Trx4 sport with OD/UD GEARS I would disagree. I'm a trail runner and I like OD/UD. It doesn't hurt with slow, straight driving, but it sure helps climbing! If you have a fast rig then you wouldn't want it, but otherwise I do it. Heck, even some monster truck guys run OD and/or UD gears. |
Re: Trx4 sport with OD/UD GEARS Quote:
If you are not competing, I wouldn't bother with it. I have tried it on other rigs and don't really like it, even for comps. But, its your rig, if having OD/UD on it puts a bigger grin of your face, then it is the right mod for you. |
Re: Trx4 sport with OD/UD GEARS Comping or not, I prefer either UD rear or OD front gears, sometimes OD/UD together is a bit too much imo. Try UD rear gears only and see, that's how I run my SCX10. Definitely helps increase steering and climbing. |
