Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Marine grease question
Old 06-18-2019, 02:16 PM   #1
Default Marine grease question
I remember reading that people use marine grease when building their kits if they plan on running in water/mud...
Just got a new gmade GS02 and was planning on replacing the supplied grease with marine grease. Are there any areas that I shouldn’t use this? I.e. transmission?
VR6 BeelzeDub is offline   Reply With Quote
Old 06-18-2019, 02:42 PM   #2
CODYBOY's Avatar
Default Re: Marine grease question
It should be fine on any of your gears ie tranny, transfer, axles.
Ernie
CODYBOY is offline   Reply With Quote
Old 06-18-2019, 03:12 PM   #3
Red Grease used in Boat trailer bearings.
Lucas brand
Rocky Heap is offline   Reply With Quote
Old 06-18-2019, 04:34 PM   #4
Awesome! Thanks for the replies
Old 06-18-2019, 09:02 PM   #5
Originally Posted by hobbyjumper View Post
Use it liberally--it's good stuff. Personally, I use Mystik® JT-6® High-Performance Marine Grease #2
I appreciate the way that even after bombing around in the creek, there is still a good layer on the bull and pinion, and inside the tranny, if I were to look.
Also, get in the habit of oiling the moving parts of the undercarriage with 3in1 or similar, to prevent rust and make things slippery and quiet. Especially the U-Joints. Even a drop on the motor commutator is good. Splashing will remove most of it, so reapply, reapply. Only takes a minute.
Do not oil the plastic drive shafts.
Cheers...
ps: Colour doesn't matter. There are no grease industry standards vis a vis red, blue, green etc.
Just "Use liberally"? or "pack the pumpkin"? I've heard both. Seems a full crankcase would cause a lot of drag. Which is the recommended method?
punkindrublik is offline   Reply With Quote
Old 06-18-2019, 09:34 PM   #6
I make sure the any engagement surfaces (ie gear teeth in a non locked diff) are completely full, as well as there being a good coating on any area that might contact the diff case itself under a hard bounce. Running RC rally cars, I've never had an issue, and never had a slow down from it. I don't know anyone who packs the whole thing full.
GCi in ATX is offline   Reply With Quote
Old 06-19-2019, 05:52 AM   #7
Way too many people do that then pretend they don't need to do maintenance because marine grease.
svt923 is offline   Reply With Quote
Old 06-19-2019, 10:31 AM   #8
@Hobbyjumper - Didn't think of oiling the moving parts of the undercarriage with 3in1... Thanks
Any area that might contact the diff in case of a hard bounce? Drive shafts?
Thanks again for all the good info/suggestions!
Old 06-19-2019, 12:52 PM   #9
I use this:
I would not use axle bearing grease as it's too thick and firm. This outboard motor grease is nearly liquid state, thinner than vaseline.
Free-running and waterproof. Goes in all my diffs and gearboxes.
Browneye is offline   Reply With Quote
Old 06-19-2019, 01:46 PM   #10
Moderator
JatoTheRipper's Avatar
I don't pack mine full. I think it's a stupid and wasteful practice. But I don't do maintenance because lazy!
Old 06-19-2019, 10:55 PM   #11
Just mainly the edges of the gears. In a rally car you don't have near the suspension, and it's very possible to have a lot of violent chassis slapper landings (depending on the course and your driving style). Some manufactures make diff case's that are very, very tight, and any play that's built up can result in the drive pinion or ring gears whacking the interior of the diff case if you really blow a landing. I actually took a scallop of plastic out of the case (and we can guess what happened after that) one time from a very badly taken jump, along with a fully pinned throttle. I also almost blew the diff case off the body pan (IFS and IRS in that car), so that might have had something to do with it too. Better greasing probably wouldn't have helped, but it makes me feel better lol.
Old 06-23-2019, 11:40 AM   #12
I use grim racer speed grease. It’s waterproof, thick and sticks. If anything I have had to make sure my diff gears don’t have slop because this grease seems unique in its ability to cause ring and pinion slipping. Check it here
https://images.amain.com/images/larg....jpg?width=475
MeanTT is offline   Reply With Quote
Old 07-12-2019, 10:27 AM   #13
Lucas Oil blue waterproof marine grease. I do a tear down after every run in water and mud. Dry trail run gets a tear down every third time out unless something goes Tango Uniform.
RABIDFOX is offline   Reply With Quote
Marine grease question - Similar Threads
Marine grease CC01 Vino Tamiya XC/CC01 6 02-15-2017 07:37 AM
The Few, The Proud, The Marine Grease JKWrangler Newbie General 8 12-14-2014 11:08 PM
can you use marine grease for differentials kgb424 General Crawlers 5 06-29-2013 10:07 AM
Marine Grease instead of Green Slime? solomon7 General Crawlers 2 01-13-2011 07:44 PM
