06-26-2019, 10:03 AM | #1 |
Newbie Join Date: Jun 2019 Location: Long Beach
| New to crawling and just got the Element RC Senduro
So i just got the Element RC Senduro and really excited to take it out to some rocks. As i was driving it around the house i noticed that when it goes pretty fast in reverse vs going forward. Is this normal w/ a rock crawler?
06-26-2019, 10:20 AM | #2 |
| Re: New to crawling and just got the Element RC Senduro
Not normal, but it happens. The first thing to do is to zero all of the trims on the radio and them recalibrate the ESC to the radio's throttle. |
06-26-2019, 10:34 AM | #3 |
Thanks for the reply. Will try to do that.
06-26-2019, 11:11 AM | #4 |
It is also possible the throttle on the radio is reversed and the motor leads are backwards. The ESC is actually running in reverse but with the motor wires backwards, it will spin the opposite direction so everything appears correct. Reverse ends up faster because a lot of brushed ESCs can pass more amps in the forward direction than in reverse. |
06-26-2019, 11:15 AM | #5 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
also try not to "drive it around the house" much. the overdrive front wheels don't play nice with the rear unless you are on dirt.
06-27-2019, 06:37 AM | #6 | |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
| Re: New to crawling and just got the Element RC Senduro Quote:
If it cant drive around a house how well is it gonna do on the rocks? | |
06-27-2019, 07:12 AM | #7 |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
| Re: New to crawling and just got the Element RC Senduro |
06-27-2019, 09:26 AM | #8 | |
06-28-2019, 09:12 AM | #9 |
Rock Stacker Join Date: Apr 2019 Location: Olympia
I also noticed this same thing with mine as well. The reverse is too touchy, a small reset often meant running backwards out of control off a ledge... May have to just go get a HW1080 today at lunch.... got em in my TRX4-Sport and Gen 8, might as well add another to the family...
06-28-2019, 09:33 AM | #10 |
taking notes here... i might try swapping the motor wires and running the TX throttle reversed.
06-28-2019, 10:44 AM | #11 |
huh. might have to try that. i made a crazy assumption freewheel = no drag brake. looks like i need to do some experimenting... once my 79 ford ascender is drivable.
06-28-2019, 11:20 AM | #12 |
Its a 70/30 transmitter so the reverse is super touchy. That is normal. You can tone it down with a different ESC. not much that can be done on the transmitter, but turning up the d/r on the throttle channel will help smooth it out at small throttle amounts.
06-28-2019, 11:47 AM | #13 |
so if i swapped to a different tx/rx…? bummer as i actually like the RTR radio gear for the 3rd channel. ironically i bought a 4 ch. radiolink for a winch setup but discovered none of the channels are 3 position lol woops! |
06-30-2019, 02:06 PM | #14 |
06-30-2019, 02:08 PM | #15 | |
Sent from my SM-N950U using Tapatalk | |
07-01-2019, 06:16 AM | #16 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: New to crawling and just got the Element RC Senduro Go do figure 8s in a paved parking lot with a full size truck in 4wd and see how long it takes to break an axle or a pinion. Having mismatched gear ratios is fine as long as there's a little bit of slip, but on high grip surfaces, it's going to ruin something. Best case scenario is that it just causes excessive wear to some of the gears, but it could break a gear or an axle depending on how stupid you get on the carpet.
07-01-2019, 07:11 AM | #17 |
Back in the 90s when I worked at an auto repair shop, we kept getting a customer who blew out his transfer case on his xj Cherokee. Got like 3 rebuilds from us under warranty. We later found out this clown was driving around constantly in 4 high.
07-12-2019, 10:23 AM | #18 |
Pebble Pounder Join Date: Mar 2011 Location: Florida Gulf coast
Don’t ever do figure 8s in a 1:1 HMMWV outside the motor pool with your Captain watching. You will wind up mopping the deck, outside, in a rain storm. Ask me how I know. |
07-12-2019, 11:17 AM | #19 |
HOW DO YOU KNOW? it was in a HMMWV that i got my military nickname... GUNNEREA my last name was pronounced wrong. sounds like RAY but when assigned my position it was pronounced REE-YUH. |
07-12-2019, 12:15 PM | #20 |
RCC Addict Join Date: Sep 2017 Location: The OC
Did OP get the fix for his Q? Posted elsewhere...in the updates thread. |
Tags |
element rc, reverse, senduro |
New to crawling and just got the Element RC Senduro - Similar Threads | ||||
Element of Survival | Hunter711 | U4RC | 0 | 05-08-2014 07:48 PM |
Out of my element.. 3s motor choices? | monkeymagic9 | Rally | 7 | 09-24-2013 09:29 PM |
New element discovered | JasonInAugusta | Chit Chat | 8 | 05-24-2010 11:20 PM |
