08-21-2019, 12:16 PM | #1 |
Newbie Join Date: Aug 2019 Location: Whitehouse,Tn
| Hobbywing axe?
Are they worth the $200 price tag?
08-21-2019, 02:20 PM | #2 |
| Re: Hobbywing axe? |
08-21-2019, 02:44 PM | #3 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
| Re: Hobbywing axe?
Wouldn't touch it with a ten foot pole :/
08-21-2019, 04:07 PM | #4 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
| Re: Hobbywing axe?
No, especially since you can't use either component with other brands. Get a Holmes Hobbies/Castle Creations setup and don't look back...
08-22-2019, 09:25 AM | #5 | |
| Re: Hobbywing axe? Quote: | |
08-22-2019, 09:28 AM | #6 |
| Re: Hobbywing axe?
Ended up going with a hobbywing 1080 and a rc4wd 35 turn motor.
08-22-2019, 03:17 PM | #7 |
Quarry Creeper Join Date: May 2009 Location: Scotland, UK
| Re: Hobbywing axe?
Hobbywing 1080 and most brushed motors is a good combo I just swapped my 1080 and Yeah Racing Hackmoto 13t 5 slot, to an AXE 2300kv Under no load, on the flat start up smoothness and slow speed control is about the same. But power, torque and top end the brushless Hobbywing is better by quite a bit |
08-22-2019, 04:47 PM | #8 | |
| Re: Hobbywing axe? Quote: I used the Forum search feature, not Google search - and I came up with a 24-page thread with 469 posts on the HobbyWing Axe. I was trying to be helpful. And, since I did that for you, all you had to do was click on the underlined hyperlink entitled "Hobbywing Xerun AXE" and read. But, whatever... | |
08-22-2019, 05:52 PM | #9 | |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
Sent from my SM-J327VPP using Tapatalk | |
08-22-2019, 07:21 PM | #10 | |
08-22-2019, 07:41 PM | #11 | |
08-22-2019, 08:23 PM | #12 |
Newbie Join Date: Sep 2018
| Re: Hobbywing axe?
My kid and I have been RC crawling for quite a while and after his brand new 1080 caught fire between comp courses, I bought him an AXE system and we both liked it so much that I bought one for my C2 comp rig. I have a mamba x/ slate combo in my Wraith, a mamba micro x/ outrunner combo in my Marlin TF2 C1 comp rig, and a micro x/ hobbywing juststock 25.5T in not other C2 and the AXE is the best crawling combo. The mamba x/ slate has more punch and top end, but for my style of slow crawling, I love the AXE. The 200% drag brake is epic and the low speed control is awesome. Sent from my iPhone using Tapatalk |
08-22-2019, 11:54 PM | #13 | |
Newbie Join Date: Sep 2018 Location: Johannesburg - South Africa
I have to agree! With a 9 tooth pinion I can make a snail look rapid! Have 6 AXE systems installed across the various rigs. Testing the 550 can currently, just a bummer the 11 pinion is the smallest I can go. | |
08-23-2019, 04:07 AM | #14 |
Pebble Pounder Join Date: Jan 2017 Location: @scaleobsession on instagram
| Re: Hobbywing axe?
I'm running an axe system in a 9.5lb rig and couldn't be happier with it. Plenty of low end control, but when I need some power its there.
05-10-2020, 06:50 PM | #15 |
| Re: Hobbywing axe?
I found an axe 3300 550 a few weeks ago for $150 so I got it in my wraith now and swapped out my 1080 to my sons trx4 and I have to say I like it. When I get a rig I want to set up for comp style crawling I’ll most likely go with a basher/bouncer set it in the wraith. Then put the axe in the comp rig.
05-11-2020, 05:52 AM | #16 |
| Re: Hobbywing axe?
I typically run Holmes motors in my rigs with a combination of different ESC's - (These include both brushed and brushless systems). However, several features of the AXE system piqued my interest while I was building my Capra over the Winter. I went ahead and picked up the 540 / 2300kv system (189.00), and installed it in the Capra. I've got enough packs and trigger time on it now where I feel I can weigh in on any debate about it. The GOOD: Super quiet running system Great start up Smooth power delivery Plenty of wheel-speed (3s) Plenty of torque The BAD - (Not so much bad as quirky): The system can be fickle about updates Following updates, it seems you often have to go through the re-binding process Overall, I've been very pleased with this system in my Capra. Start up and low speed creep is right on par with my Mamba X / 1800kv Revolver system, and as mentioned, MUCH QUIETER. I also feel the roughly $200 or so for the system is right in line with other systems from Castle, HH, TEKIN, etc. The one thing I have noticed is that for some reason, people who do not own and have never run this system always seem to want to weigh in. I'm not sure what that's all about, but I'd take any opinion from that perspective with a grain of salt. |
05-11-2020, 12:27 PM | #17 |
Rock Stacker Join Date: Jan 2015 Location: westminster
| Re: Hobbywing axe?
I e got one im my gen 8 axe and its smooth as silk. I love it.
05-13-2020, 03:40 PM | #18 |
Newbie Join Date: Jul 2017 Location: Tri Cities
| Re: Hobbywing axe?
I have an Axe setup for my SC10ii that I have been building for the last week. The one thing I noticed so far is that the cooling fan doesn’t plug into the Esc for power. So know I have to split a connection so i can use all 4 of my channels in the rx. I’m setting up hi/low shift, and dig.
Hobbywing axe? - Similar Threads | ||||
Hobbywing Xerun AXE | Jboucher | Electronics | 565 | 06-27-2023 05:45 AM |
Hobbywing AXE 550 System | yazfat | Electronics | 10 | 06-14-2019 10:40 AM |
Hobbywing Axe + External BEC wiring. | Tree_Mafia | Electronics | 2 | 04-28-2019 05:32 AM |
RC4WD Gelande Defender / Hobbywing Xerun Axe | TerryTurnip | 1.9 Scale Rigs | 2 | 04-04-2019 04:07 AM |
PRICE DROP Hobbywing AXE Lineup! | RPP Hobby | RPP Hobby | 0 | 12-13-2018 12:37 PM |
