01-17-2020, 09:37 AM | #1 |
Newbie Join Date: Dec 2019 Location: prince rupert
| half power pls help
newbie- my kyosho foxx VE seems to be only running at half the speed it normally does, any input on what the problem could be would be greatly appreciated. thanx
01-17-2020, 08:59 PM | #2 |
Rock Crawler Join Date: Nov 2019 Location: Erie
| Re: half power pls help
What electronics are in the truck? Change any electronics before the issue started? Did you try recalibrating the esc/radio?
01-18-2020, 12:25 AM | #3 |
Newbie Join Date: Feb 2018 Location: Greensboro
I’d start with making sure you have good batteries in your controller then maybe check out the esc, pretty much just trial and error from then on ... that would be my thought process atleast idk much
01-18-2020, 04:37 AM | #4 |
i have a KR-200 syncro transmitter and an orion esc, i tried to convert it to double castle 60,000 rpm max motors with double mamba monster 2s but need to many odds and ends. so i switch back to the original setup (the one i have now) and it’s running sluggish or half power it seems like. My battery’s checked out just fine as well. and now the back wheels don’t even spin when i hit the throttle
01-18-2020, 12:30 PM | #5 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
Possibly gear mesh between transmission spur gear and motor pinion gear too tight? Remove pinion gear from motor and see if axles and transmission spin freely.
half power pls help - Similar Threads | ||||
half leaf, half coil, ford ascender mashup | Itali83 | Vaterra Ascender | 24 | 09-20-2017 11:37 AM |
Video - Half Wraith Half Exo but ALL FUN! | PSCMedia | Axial Wraith | 8 | 10-05-2013 09:19 AM |
half bronco half tuber build | crawler king 17 | HPI Wheely King | 0 | 01-21-2008 02:11 PM |
anyone every built a half cane, half stick/4 link? | STANG KILLA SS | Tamiya Clod Buster | 8 | 09-26-2007 12:41 PM |
