04-26-2021, 03:25 AM | #1 |
Newbie Join Date: Dec 2012 Location: Dayton
| Crawler questions.
So, Im not a noob on RC in general but Ive never had a crawler so I have crawler specific questions. I have no intentions of comping but I want a comp quality crawler but I also want something that has really good after market support. Im thinking about picking up a Bully 2 kit because my understanding is that MOA with a dig is superior to solid axle set ups. So the first couple of questions I can think of right off the bat are: 1) Whats the after market support like for the Bully 2? 2) How exactly do you set up a 2 motor design using two ESCs? I mean how do you tie both ESCs into the RX? 3) What are some high quality ESCs and Motors that I should consider using? Something along the lines of Tekin or Castle quality. 4) my understanding of a dig is where you are able to shut down the rear and drag it along using only the front tires. How do you set up the dig exactly? 5) How to know when you should be using the dig? Thanks in advance! |
04-26-2021, 07:00 AM | #2 |
| Re: Crawler questions.
Yes, MOAs can crawl circles around a scale rig, that is what they are made to do. 1. Hardly any at all. 2. You can get a dual motor ESC, like the Novak M2. You can run dual ESCs like the FXRs, tie each one to its own channel on the TX/RX, then use the radio's mixing for dig and burn control, most aftermarket radios have built in modes for this. 3. FXR is really the gold standard for MOA. 4. Dual ESCs, that will be in the radio. "Exactly" depends on the radio system you run. 5. Experience. |
04-26-2021, 07:29 AM | #3 |
there also the sporty/shafty class crawler not quit as capable as a moa but close and its alot simpler and cheaper to build with more aftermarket suport also comp worthy but in a different class
04-26-2021, 11:18 AM | #4 |
Are there better MOAs out there than the Bully 2 that have better after market support? Or are there other MOAs close to as good as the Bully 2 with good after market support?
04-27-2021, 08:46 AM | #5 |
Pebble Pounder Join Date: Jul 2009 Location: Colorado
I was where you are not long ago. No one is really making an MOA kit besides RC4WD that I am aware of. It tends to be pretty specialized. Guys will *typically* start with a couple axles and custom build around them. These days it's really the path less traveled. But if you're into it, nothing else will do. ;) That said, I find "Good aftermarket support" is kinda relative. What do you imagine you might need? I've not had issues finding what I need, even with production issues attributed to global craziness. Motors and electronics are basically the same as everyone else uses... wheels and tires are out there... paint is paint. There are still a couple people building chassis, RC4WD stocks parts and upgrades... In my limited experience, most people running serious MOA rigs end up doing custom work on their own and/or finding vendors that are a bit off the radar of the *regular* RC crowd. Dlux Fab over on Facebook for example. It's also kinda tough to know what you want (or might want) if this is your first MOA. Build it and run it. On the flip side of that coin, if this IS your first MOA crawler, the bully 2 will blow you away, even bone stock. Last edited by nathanotis; 04-27-2021 at 08:54 AM. Reason: more words, always more words. |
04-28-2021, 11:07 AM | #6 | |
| Re: Crawler questions. Quote:
Thanks man, this helps a lot. Yeah IDK what kind of after market support I might need I just know on my regular kits I dont like buying kits that have little to no after market parts cuz I like to upgrade weak parts and a lot of times I just want some bling. Got any links on how to set up dual ESCs and dig radio mixing? I need to learn how to do that. Last edited by Greywolf74; 04-28-2021 at 11:19 AM. | |
04-29-2021, 08:15 AM | #7 | |
4PM Set up for Dual ESC & MOA | |
04-29-2021, 12:26 PM | #8 |
Newbie Join Date: Mar 2021 Location: out-n-about
dig is usually most useful controlling downhill movement. the higher end spektrum transmitters have moa controls built in, look into if it is something that may help you. are you planning on competing? if so, you may want to forget about upgrades and get to know the vehicle, then upgrade what you feel you need. a person running a $500 moa everyday will beat a person running a $3000 moa once or twice a week- skill wins out over parts most of the time. |
05-02-2021, 11:48 AM | #9 | ||
Thanks for the link. I just need to see how its done in general and then Im sure I can figure out how to set up my MT4S. If not I'll google specifics. Quote:
05-03-2021, 09:08 AM | #10 | |
| Re: Crawler questions. I think that's the radio Samu uses. I found the Bully because of his videos on youtube. Dude's a serious driver and uses dig (both up and down, and sometimes sideways) as well as motor speed (front and rear biasing) so fluidly it can be hard to see: https://www.youtube.com/user/samusarka Quote:
ymmv. | |
05-03-2021, 07:25 PM | #11 |
MOA running two ESCs allows for two things, dig, and burn... Dig: Locking the back axle and using the front for power Burn: Locking the front axle and using the back for power Both have lots of uses in crawling, and the more you use them, the more situations you'll find to use them. Dig... -The main reason for dig is to have a really tight turning radius. You lock the back, turn the front wheels in the direction you want to move, and stab the throttle. The front wheels will pull the front of the crawler around, pivoting on the back axle. In most cases using dig will allow you to turn around in within the wheelbase of the crawler. Dig is very good for getting around obstacles where you don't have enough room for the back wheels to follow the front around. - As stated above, dig is also good for controlling the crawler when going down hill. On a steep slope you lock the back axle and have the front wheels pull the truck down, the back tires act like an anchor, keeping the crawler from flipping over when you stop. - Having two ESCs properly set up you can adjust power so that your front is pulling more than the back is pushing. This is very helpful when going up hill to keep the rig from flipping over backwards. Burn... - Not as useful as dig, but it still has its place. With no directionality for the back wheels, the burn will allow the crawler to slide its back axle towards the direction of gravity (think side-hilling). Or, you can put the front right tire on an obstacle, burn with the back axle and have the crawler pivot. These are just general examples, but like I said, the more experience you get with this functionality, the more you'll use it. Shafties have dig as well, but I haven't seen one with burn. My Capra is set up for a 3-position dig allowing for 4WD, FWD with the back axle freewheeling, and dig with the back axle locked. This is ran off of my DX5R. |
Crawler questions. - Similar Threads | ||||
New to RC. First Crawler on the way. A few questions... | TheNewb | Newbie General | 12 | 11-19-2012 09:28 AM |
New crawler with questions | studboy62 | Losi Micro-Rock Crawler | 5 | 05-31-2011 08:38 PM |
questions about my new crawler | peterbilt | Newbie General | 11 | 03-14-2010 10:59 PM |
A few questions from a new crawler | Killa-Cotton | HPI Wheely King | 2 | 01-06-2010 02:15 PM |
new crawler, same questions | Ducktape | Newbie General | 10 | 04-13-2009 11:01 AM |
