02-22-2020, 01:42 PM | #1 |
Newbie Join Date: Jan 2020 Location: Annapolis
| Hobbywing 1080 and flysky gt5 problem
I am trying to install a hobbywing 1080 on my truck but can't get past setting it up. I hold the set button and power it on and I get the beeping like I'm supposed too but when I push the set button for the neutral setpoints I get nothing other than the beep and flash stop. I know I'm doing it correctly because I can swap to my old reciever and radio and every works no problem. It's something to do with the flysky but what do I need to do to make it work? Sent from my SM-G965U using Tapatalk |
02-22-2020, 01:53 PM | #2 |
Rock Crawler Join Date: Nov 2019 Location: Erie
| Re: Hobbywing 1080 and flysky gt5 problem
I had the same issue with a GT3C radio and a Hobbywing 1080. Researched it and had to switch the motor leads coming from the esc, and reverse the channel 2 (esc) setting on the radio. Tried it again and it programmed fine.
02-22-2020, 03:17 PM | #3 | |
| Re: Hobbywing 1080 and flysky gt5 problem Quote:
Sent from my SM-G965U using Tapatalk | |
02-23-2020, 11:25 AM | #4 |
I ended up factory resetting the radio then rebinding. Worked no problem after that. Sent from my SM-G965U using Tapatalk |
Hobbywing 1080 and flysky gt5 problem - Similar Threads | ||||
New FlySky controller? FlySky FS-GT5 6 Channel Transmitter & FS-Gi6 Receiver Set | soze | Electronics | 221 | 01-16-2024 12:49 PM |
FlySky FS-GT5 how are you liking it | m1009cucv | Electronics | 94 | 01-05-2022 06:34 AM |
Flysky GT-3C vs GT5 | Stomp | Electronics | 14 | 09-28-2019 08:43 PM |
