05-29-2020, 12:00 AM | #1 |
Newbie Join Date: May 2020 Location: Tacoma
| When to use Loctite
I just got my first RC vehicle (Axial F100) and within less than two weeks I had a screw fall out. It was the screw that holds the steering link to the servo horn, so it made for an interesting field repair and a cautious drive home! I checked some fasteners before I drove it for the first time, but I don't remember if I checked them all, so perhaps this was loose from the factory, or maybe it just worked its way loose in a very short order. Is it normal for things to come loose so quickly? When I go to install a replacement screw, should I use Loctite? More broadly, are there general rules for when you should or shouldn't use Loctite in RC crawlers? I design and build commercial espresso machines, and we use a lot of Loctite, but only on metal. The few plastics we work with are all acrylic, and Loctite does amazingly nasty things to acrylic, so I've just gotten used to the idea that you never use Loctite near plastic... but I realize not all plastics are the same. Any advice on Loctite dos and don'ts would be much appreciated. Thanks! |
05-29-2020, 12:19 AM | #2 |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: When to use Loctite
Simply rule to follow: ALWAYS use Loctite (always blue, NEVER red) whenever you have a metal screw going into metal. NEVER use Loctite when dealing with metal into plastic. Note that NOT all nuts are all h metal. If the screw is going into an all-metal nut, use Loctite...and, if the screw is going into a locknut, sick as a Nylock nut, NEVER use Loctite. ~ More peace, love, laughter & kindness would make the world a MUCH better place |
05-29-2020, 07:20 AM | #3 |
You've got the right idea using threadlock on metal to metal connections, and not using it in plastic threads. These trucks see alot of stress/flex when in use, so it's not uncommon for hardware to slowly loosen. Occasionally torque checking (which is not the same as simply "tightening") your wheel nuts, shock and link bolts, driveshaft through pins, and all steering hardware will go a long way towards keeping your truck reliable.
05-29-2020, 08:21 AM | #4 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
As you are familiar with Loctite you may know about purple loctite. This is the blue loctite equivalent for fasteners smaller than 1/4" dia. I've been promoting this for a couple of years now and I haven't had any issues using it on the small fasteners we use on our RCs. Don't know if anyone else does it this way but I put a buttonhead screw through from the back side of the servo horn and long enough to be able to use a narrow nylon locknut to hold the steering arm in place. Works well for me. |
05-29-2020, 11:35 AM | #5 | |||
| Re: When to use Loctite Quote:
05-29-2020, 12:52 PM | #6 | |
Just snug it up on plastic and give another 1/2 turn or so. Just remember you dont need to kill it just snug it up. If metal to metal you can go pretty tight just remember these are small fasteners so again you dont need to kill it. Also worth noting when screwing into plastic alone having the screw nice and snug will act like a lock nut by compressing the plastic. Sometimes when passing a fastener through a plastic hole but going into metal I will forgo the loctite so I'm not melting the plasic it passes through and I count on compressing the plastic to do the "holding". | |
05-29-2020, 02:20 PM | #7 | |
05-29-2020, 02:58 PM | #8 |
RCC Addict Join Date: Jun 2008 Location: Mudville
Torque spect? Make it snug, turn it a bit more till its tight. Leave it be. Locktite will soften Plastic. It has a slight chemical reaction and over the span of a week or 3, the plastic will soften and the screws will be loose. That is the main reason we don't use locktite in plastics. Also a reason why we clean any surfaces that have excess locktite on them, as even on the surface of a plastic piece like a Rod End where you may locktite the screw into the link ends, you want to keep it clean where it meets the plastic rod end, or it can soften the rod end, leading to a failure of the screw being pulled out of the now soft plastic end. Never, Ever, Never, use a Stainless Steel Screw in an Aluminum Part. Trust me. The Stainless Screw threads will gnaw the Aluminum treads and that will cause them to bind up, making it very hard to remove without damaging the aluminum piece with needing at least new threads and a bigger bolt for them. So locktite any OTHER Metal to metal connection, but because you will never put a Stainless Steel Bolt into an Aluminum piece, there is no need to locktite them. heh But as far as "Torque Spects, if its in Plastic, if its Tight with finger strength, its probably tight enough. If I am tightening a bolt into aluminum, I make it finger tight, then give it JUST an Smidge more. With the locktite, it wont come loose so long as you allow the locktite to cure. Only time you may want to use RED is in High Heat Situations. IE something that is metal with a bolt and is in the 225*f or hotter range. Ie Exhaust bolts on Nitros and 1/5 scale assets. Nothing we use gets that hot unless a lipo goes critical, so there shouldn't really be a need for red. Keep the excess locktite cleaned up and not on the plastic parts or threads, and don't Over tighten. If if feels finger (not weak fingers) tight, it is tight enough. Always good to go over the rig every 2 or 3 runs checking bearings, bolts etc anyways. And that gives a time to maintain, clean, and hopefully not find any gremlins. |
06-01-2020, 03:58 PM | #9 |
Newbie Join Date: Oct 2018 Location: Salt Lake City
Will just add, use sparingly! Most use too much - more does not hold better. Just a light coat on the threads - should not drip off the screw.
06-01-2020, 09:06 PM | #10 |
| Re: When to use Loctite |
06-01-2020, 11:11 PM | #11 |
| Re: When to use Loctite Actually, very easy to do. Start by squeezing a few drops onto a piece of plastic (never paper...it will absorb the Loctite). Then, for each screw needing Loctite, I place the screw onto the hex driver, hold it in place with a finger (or nail) from the other hand, and then lightly 'dip' the lower edge of the screw into the Loctite...perfect amount (almost) every time. The only real exception would be the really tiny M2 & M2.5 screws...but, with practice, even those become easier. Sent from my SM-N975U using Tapatalk |
06-01-2020, 11:50 PM | #12 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
Few tips not sure if mentioned- > Use a toothpick, a Q-tip, or a folded square of toilet paper to keep things from getting messy. Sometimes locktite wants to seep out of the tube before, during, or after use. Don't squeeze the tube too hard. I just shake it a little to get the fluid to the tip. If too much comes out, just wipe it up before it drips everywhere. > Also if you're worried about using too much on a certain screw, then you can just drip the locktite onto a toothpick or paperclip. Then touch that to the screw or even into the hole that the screw is going to go into. > Some precision jobs are much easier ( especially with really small screws or with screws that are going into hard to access areas) if you first put the screw onto the tip of the hex-driver.. then [gently] apply the locktite to the screw. This way your fingers never touch the threads and everything stays clean. *** If you ever apply too much loctite, just briefly/ delicately touch a Q-tip to the screw to wick away the excess. With a little practice you can easily control exactly how much loctite you want on the screw. And always always... SHAKE WELL before use. |
07-26-2020, 11:44 AM | #13 | |
Newbie Join Date: Feb 2020 Location: NYC
Sent from my iPhone using Tapatalk | |
07-26-2020, 12:03 PM | #14 |
Speaking of Loctite dripping from screws... I ordered this for my next build: "Loctite 506166 All-Purpose Medium Strength Anaerobic Threadlocker Stick, Blue, 9-Gram" Perfect for use on smaller screws, it's a waxy Chapstick-like product. Just touch the end of your screws and bolts to it and then thread them in. |
07-26-2020, 01:44 PM | #15 |
Wow never seen that thread locker stick before! Definitely ordering some ASAP Sent from my iPhone using Tapatalk |
07-26-2020, 02:10 PM | #16 | |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
Thank you Durok! Just ordered some ETA - apparently I live under a rock. I just asked my coworker if he was aware of this. He said he’s been using it for a little while. Last edited by Benp; 07-26-2020 at 02:15 PM. | |
07-26-2020, 03:44 PM | #17 |
Yeah, I've always hated the tiny bottles of the fluid, so hard to get it out in the proper amount, and always wasting some of it... This stuff is MUCH better! |
07-26-2020, 06:59 PM | #18 |
Thank for the stick info...gonna have to order some. ~ More peace, love, laughter, & kindness would make the world a MUCH better place |
07-26-2020, 08:59 PM | #19 | |
~ More peace, love, laughter, & kindness would make the world a MUCH better place Last edited by Panther6834; 07-26-2020 at 09:01 PM. | |
07-26-2020, 09:17 PM | #20 | |
Ask me how I know. lol | |
When to use Loctite - Similar Threads | ||||
Loctite, loctite and... | Hulldiver | Newbie General | 24 | 02-01-2014 02:41 PM |
Which loctite do you use????? | donhd04 | Tools, and Procedures | 22 | 08-31-2012 07:44 PM |
Loctite | Onebdgti | General Crawlers | 3 | 01-08-2012 05:57 PM |
Loctite ? | muddywaters | Axial Wraith | 8 | 10-04-2011 01:21 PM |
Loctite v2 | ripper7777777 | 2.2 Scale Rigs | 49 | 06-10-2009 09:42 PM |
