Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: calibrate AE-6 ESC/Rx for Axial 1/24
Old 09-07-2020, 12:30 PM   #1
Default calibrate AE-6 ESC/Rx for Axial 1/24
Guys, I am trying to install a new ESC for my Axial 1/24 but, even after all the connections transmitter is not working (forward / reverse/ steering are not working). All I see is a slow red blinking led. Even the front LEDS are not lit up.
Please let me know if there is a place where I can find instructions.
Thanks
kaartman is offline   Reply With Quote
Old 09-07-2020, 04:23 PM   #2
Default Re: calibrate AE-6 ESC/Rx for Axial 1/24
Pictures of your setup would help. We don't know exactly what you have or or what you've done.
I assume you're using an aftermarket ESC plugged into the ch2 throttle of the factory ESC/RX? How'd you connect everything else?
If the stock 2-in-1 electronics have been bound to your transmitter You don't need to bind everything again. It should work
Sent from my Pixel 3 XL using Tapatalk
spoo76 is offline   Reply With Quote
calibrate AE-6 ESC/Rx for Axial 1/24 - Similar Threads
ESC will not calibrate kpinks Newbie General 10 05-28-2020 09:37 PM
calibrate vxl-3s RusT808 Electronics 5 04-20-2011 10:23 AM
Can't calibrate my Tekin FX-R cliffhanger007 Electronics 23 12-01-2010 03:45 AM
Can't calibrate Sidewinder freds40 Electronics 3 12-21-2008 09:27 PM
esc won't calibrate SuperBad Electronics 6 03-18-2008 08:55 PM
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
