09-17-2020, 06:53 PM | #1 |
Newbie Join Date: Aug 2020 Location: Spencerport
| Rock Rey - Excess space in the battery compartment
Hello everyone, So I got my new Rock Rey a few weeks ago-my first RC and it is a freakin' blast! I am running a 3S Lipo in it and there seems to be a lot of space in the battery compartment for the battery to move around when driving it. We're talking about 3/8"+ along the side and the top of the battery. I run it on bumpy terrain, fields, and it sees some air time and hard landings. No crawling. I put a 1/4" piece of rubber weather seal at the bottom edge of the tray opposite the battery door. It seems to hold the battery in place better so the battery does not move around too much. I was thinking of installing some foam in strategic places to provide cushioning for the battery to soften the batterys ride. I'm not talking lining the compartment because I don't want to impede airflow, I'm thinking foam under the battery and small pieces in a few places on both sides and the top to provide cushioning. Have any of you ever done this? |
09-17-2020, 07:59 PM | #2 |
Pebble Pounder Join Date: Feb 2019 Location: SIGNAL MOUNTAIN
| Re: Rock Rey - Excess space in the battery compartment
Is the battery spacer in the battery compartment already? Because that takes up about 1/4" of the space on it's own. Also, what size batteries are you running? Most non-crawler sized, aka monster truck, 2s and 3s batteries fill that compartment. And Losi recommends hardcase batteries for the Rock Rey. I have one of those as well.
09-17-2020, 08:54 PM | #3 | |
| Re: Rock Rey - Excess space in the battery compartment Quote:
I am using Lectron Pro 3S Lipo, 5200mah-11.1V. It is not a hard case battery. I had to take the spacer out because the battery would not fit in the compartment. I understood the spacer was to be used with 2S batteries. Is a hard case battery that much bigger than a soft wrapped battery? | |
09-18-2020, 07:10 AM | #4 |
It really just depends on the brand/size of battery. I use both 2s and 3s in my Rey. 137x45x25mm hardcase batteries from SMC and they are a perfect fit with the spacer installed. With the spacer out, you can fit a huge 3s battery in there. I believe one of the advantages of the hardcase is the consistent size and shape keep it from flopping around in the compartment. Just look around at different brands and battery capacities that fill those measurements. A lot of companies will offer both hardcase and softcase batteries. otherwise, you'll have to pack a lot of foam in there to keep the battery from getting beat up.
09-18-2020, 05:37 PM | #5 | |
09-25-2020, 10:22 AM | #6 |
Newbie Join Date: Dec 2016 Location: Magnolia
hawg78: When I buy RC upgrade parts like shocks, many are packed in closed cell foam and I keep those pieces in a box. I use an electric knife to cut them into spacers like what you need. Could that be an option for you?
Rock Rey - Excess space in the battery compartment - Similar Threads | ||||
Gmade Gom Battery Compartment Size? | the.ronin | G-Made Crawlers | 4 | 11-06-2019 08:31 PM |
Rear sway bar hits battery/compartment | Lavaheadache | Vaterra Twin Hammers | 3 | 01-02-2017 04:39 PM |
Battery compartment size | Johan_Eriksson | Axial RR10 Bomber | 6 | 06-27-2016 10:32 AM |
Turnigy 3S Packs dont fit in the battery compartment!!! | djmaincheese | Axial Yeti XL | 10 | 11-26-2014 04:02 PM |
Fixing a broken transmitter battery compartment | sixty2 | Electronics | 0 | 10-08-2014 11:44 AM |
