09-26-2020, 12:35 PM | #1 |
Newbie Join Date: Sep 2020 Location: Springfield
| Setting up front suspension
Is there a guide for setting up front suspension when making a custom build? I figure you want the panhard bar on the front to be parallel to the axle line, and same with the steering link. How important is pinion angle? |
09-30-2020, 06:42 AM | #2 |
I wanna be Dave Join Date: Aug 2004 Location: central VT
| Re: Setting up front suspension
Pinion angle setting is going to depend if your axles allow you to clock the c-hubs so you can independently set your pinion angle from your caster. I like at least 10 degrees of caster, ideally with the pinion pointing up towards the trans output. If you can't separately adjust your caster from pinion angle then just dial as much caster as your comfortable with as long as your drive shaft pivots dont hang down below the lower links and doesn't bind at full drop and your all set.
11-17-2020, 08:57 AM | #3 |
RCC Addict Join Date: Aug 2017 Location: Fredericksburg, VA
To your panhard bar question, ideally the panhard bar would be parallel with the axle at ride heigh but this is not normally possible on a crawler given the long suspenion travel and limited space. But more important is to have the panhard bar and steering drag link as parallel as possible. This will reduce bump steer which can be pretty annoying.
11-28-2020, 12:49 AM | #4 |
Rock Stacker Join Date: Oct 2020 Location: San Jose
Start with I'm not an expert by any means. As inspector said, you want the pan hard and steering link parallel. You can adjust the length of the upper and lower links to change the pinion angle (point it towards your transfer case). And the height of the links will change your (anti)squat and dive. If you google 3 or 4 link calculator, there is a ton of info out there. Crawlerpedia, Jeep Forums all have similar tools. Here is a video of one of the tools. https://youtu.be/nQMrnsOAPig I'm not sure this scales 100% though. The reason being is we can scale the dimensions but the RCs are way under weight. If it's and 8 lb RC it wold 80 lb full size. To be true scale it would be 500-600 lbs. We also have like 1,000 HP by comparison. When you align everything don't forget the tow. You probably want a little bit of tow out to keep it tracking straight. I'm not sure you can adjust the camber and other angles? So you are probably limited to tow and caster. Let us know how it comes out - post some pix. |
12-01-2020, 01:41 PM | #5 | |
Newbie Join Date: May 2020 Location: Tacoma
| Re: Setting up front suspension Quote:
The thing is that we describe the scale in one dimension - a 1/10 scale truck has a wheelbase that's 10% of its 1:1 counterpart. But, if you want "realistic scale weight," that really means having roughly equivalent density. Since density is a function of weight and volume, and volume is the product of three dimensions (length, width, and height,) you have to apply the 1/10 scale three times. The rig is 1/10 length AND 1/10 with AND 1/10 height, so if you multiply those three 1/10ths together, you should end up at 1/1000 weight. If typical scale rigs run from 5-10lbs, that would be the equivalent of 5,000-10,000lb full size trucks. Depending on what vehicles you're modelling, I think scale weight actually isn't too terribly far from where it should be. Mind you - this is all just theoretical junk in my head, so I could be way off base. I'd be interested in hearing other opinions on this. Anyway, sorry for drifting off topic a bit. As for the original topic, I find suspension tuning to be fascinating, but I'm certainly still too inexperienced to help anyone with it. I've stayed pretty close to stock on my RTR SCX10.2. | |
12-01-2020, 02:20 PM | #6 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
^^ correct. Scale weight would be cubic so in 1:10 scale it would be 1 lb per 1,000lbs if I’m not mistaken. Keep in mind 1:10 scale for these trucks is kind of a ball park and not always a very precise representation of the 1:1s. As far as front axle geometry, as mentioned above have your drag link and pan hard as parallel as possible to prevent bump steer. A longer panhard will have a larger arc and therefore less axle swing, because of this I prefer pan hard mounts on the outside of the chassis rail instead of the ones that tuck under. Pinion angle depends on driveshafts but generally you want the pinion input on the axle to be parallel with the output on the transmission/tcase. |
12-06-2020, 01:22 AM | #7 | |
No worries. I love the math stuff I have forgotten so much, and it's good to go figure this stuff out once in a while. I think you are correct. Another way to think of it is the density would remain constant. Full size (assumed box) -> 10 ft x 5 ft x 5ft = 250 CF. It weighs 2500 lbs and the density is 10 lbs/CF. Scale rig (1:10) 1ft x.5ft x.5 ft = .25CF. The density is 10lbs.CF so the new weight is .25 CF*10 lbs/CF = 2.5 lbs. It would still be cool to have a 500lb RC. I believe the HP (Watts) and speed (MPH) are linear though. A small ESC with 40A (random guess) draw at 11.1V is 456W or .61HP. If the rig weights 8lbs the power to weight ratio is 8 Lbs/.61 HP= 13 lbs/HP. Which if this were a car could be a pretty quick car. And 10 MPH is 100MPH scale. I'm not sure about you, but I don't like driving 100 MPH in a 4wd truck. It gets a bit weird, sort of like jumping to light speed. Or to put in perspective it would be like have a Landcruiser with 500 HP and a top speed of 150 MPH. I can't wait for that model. | |
12-06-2020, 06:54 AM | #8 |
I wanna be Dave Join Date: Oct 2012 Location: Medina
There is an excellent post here on the forums regarding this. I read it through and through a couple years back, but can't remember who the OP was and what the thread was titled. It was clear they intimately understood 1:1 suspension dynamics and had an innate ability to apply that information to scale crawlers. I'll dig back through my posts to see if I can find it as i'm pretty sure I commented.
12-09-2020, 07:38 PM | #9 | |
Rock Stacker Join Date: Aug 2017 Location: Hinesville
Setting up front suspension - Similar Threads | ||||
Setting up my suspension? | kkipp9 | Axial SCX10 II | 1 | 11-22-2016 06:42 PM |
Front toe and camber setting? | karajabola | Axial Yeti XL | 14 | 04-28-2015 03:15 PM |
Setting up the leaf spring suspension | Cr00zah | RC4WD Trail Finder 2 | 17 | 02-13-2015 03:31 PM |
independent front suspension and front diff build | canadian scx10 | Axial SCX-10 | 1 | 02-13-2011 07:52 PM |
Setting up Front Digs... | Mutt | General Crawlers | 11 | 11-22-2005 08:55 PM |
Thread Tools | |
Display Modes | |
