10-09-2020, 10:42 AM | #21 | |
Newbie Join Date: Nov 2019 Location: Strand
| Re: Wheels vs water Quote:
Sent from my AMN-LX9 using Tapatalk | |
10-09-2020, 12:30 PM | #22 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
| Re: Wheels vs water |
10-09-2020, 03:54 PM | #23 | |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
Yeah, lol that makes since! It was about 2am when I responded, so I missed a thing or two. I personally run non vented without foams and it grips great. Sent from my iPad using Tapatalk | |
10-17-2020, 07:49 AM | #24 |
| Re: Wheels vs water
Heres how I see it. Vented with nice dry foams do likely grip the best. However, once those foams are all soaking wet your actually better off with a sealed tire/wheel that still has dry foam in it. I play in riverbeds frequently and cant stand the truck hauling around heavy water-filled tires with mushy foams inside. Yeah, people tell me to vent the tires and just hold the truck in the air at WOT to fling the water out. My experience is that the average trail truck doesnt have the wheelbspeed to accomplish this. You get like half the water out and in a few weeks you still have ruined foams. |
10-17-2020, 08:34 AM | #25 |
| Re: Wheels vs water
Well that’s correct for single stage foams. However the world has Other foams, Two Or Dual (closed cell) stage.... that don’t hold water, relying on size and air space for proper grip. I’m in the Everglades.... I never use single stage foams. Hang up and Drive |
10-19-2020, 03:51 PM | #26 | ||||
Rock Stacker Join Date: Aug 2020 Location: Finland
| Re: Wheels vs water
I don't vent tyres or wheels. Pro-Line says don't.. https://youtu.be/ht2ung1R4e8 Quote:
66% do not vent. Quote:
https://youtu.be/0Iu5lkBcXfg Quote:
I've tried driving on snow, no shrinking. No ballooning when I go to 100m(330ft)hilltop that is just 10min drive from my place. | ||||
10-19-2020, 07:04 PM | #27 |
RCC Addict Join Date: Aug 2020 Location: Jacksonville
| Re: Wheels vs water
I think he meant like a major elevation change. As in a mountain.
10-19-2020, 10:59 PM | #28 | |
Often it's colder on the mountains so it offsets the tiny pressure change.(1psi/10F) Not to mention the tyres may not be vented but certainly it's not airtight. The pressure evens out slowly. Going really high with your 1:1 car, have you ever had problems with tyre pressure and ballooning... Warning! If you waterproof your servo and receiver box, they burst open and spill their guts all over the place if you go to higher elevation where unvented tyres start to balloon. You may also notice that breathing is difficult because of the thin air. Cooking noodles takes longer because water boils in a lower temperature. | |
10-20-2020, 12:48 AM | #29 | |
Yeah, maybe second thoughts on taking my rig up an extra 13,800ft Sent from my iPad using Tapatalk | |
10-20-2020, 04:47 AM | #30 |
| Re: Wheels vs water
I used to live on the coast so 0ft above sea leval and when i went to tahoe amd crawled at 10000 for above sea leval my tires needed venting cause they were balloons and then back the other way they would suck up creating a flat spot in the tire i only needed to pull one screw to vent them but got to the point were i got tired of doing it and opened up the vents on the wheels my new place is at 3500ft and going from the beach to my house theres no change but from 0to10000ft its a huge difference I started venting my tires cause.the rim vents would clog up with dirt and would have the balooning and shrinking problems again not a big deal if you dont traval from coast to the top of the sierras i was making the trip every other week for a while enuff to see it as a problem especially with multiple rigs Last edited by ferp420; 10-20-2020 at 04:54 AM. |
10-20-2020, 05:40 AM | #31 | |
Yeah, I bet it’s fun around Lake Tahoe We drove from Indy to Oakland to Seattle and I wish I would’ve had my rig with me. We went through the sierras and Rockies, I was so mad I didn’t bring it. I’m not going to be going near that 14k ft mark, There’s good spots at 0-4K Sent from my iPad using Tapatalk | |
10-20-2020, 07:40 AM | #32 | |
Not sure why the sarcasm/aggression it’s just an observation. Some guys vent, some guys don’t. Do what you like to your RC truck and just have fun. I do a lot of things that may be a placebo but it is what it is, not losing sleep over it | |
10-22-2020, 04:10 AM | #33 | |
It's great that the Pro-Line video where they recommended not to vent crawler tires, also answer the question about tire shrinking or ballooning. I was just outside driving in snow with 1:1 car, I've never noticed that the traction on snow is better or worse depending on tire pressure. We change to snow tires when it's 50F(10C), and on -40F(-40C) the pressure is still ok. We do check the pressure to keep the tire wear even, but not because of traction. | |
10-22-2020, 08:25 AM | #34 |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
| Wheels vs water
We do winter jeep trail rides every year. Everyone airs down before we leave the shop. The airing down increases the contact patch vs not airing down. Helps immensely in the snow. At our final spot where we eat, we air back up before getting on the highway. I only slow crawl rocks and never do water or mud, so my rc tires are vented. My vehicles do lose tire pressure in the winter. If I check the pressure before I go somewhere, there will be a 7-10# difference. After driving a while and some heat is generated, the pressure is back to where it supposed to be. My tires will even flat spot a little from sitting all day when it is -20F or colder. When I leave work, the car goes “thunk thunk thunk” down the road until the tires warm up. As mentioned before, to each their own. Last edited by Benp; 10-22-2020 at 09:14 AM. |
10-23-2020, 02:33 AM | #35 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: Wheels vs water
I know it's not quite the same as crawling, but LITERALLY EVERYONE in any class of RC racing will vent either their wheels or tires (or both). Touring, short course, 1/8 scale, indoor, outdoor, etc. It's simply more consistent. Now, to me it seems pretty clear that venting offers a performance advantage of some kind, even if it is miniscule, otherwise none the pros would be doing it either. (Before y'all jump on me, YES I have tried unvented wheels/tires while crawling, with multiple different wheels, tires, foam, and vehicle combinations. It does not work better than a properly vented setup). That said, I would not vent my tires/wheels if I regularly drove through mud and water; it indeed does destroy the foam pretty quickly. |
10-23-2020, 11:14 AM | #36 |
Quarry Creeper Join Date: Nov 2016 Location: Switzerland
| Re: Wheels vs water
I'm not going argue which is better because I don't know But tires conform very nicely without venting. I usually run CI single stage foams which allow an air gap between foam and tire and this works very good for me at least. Last edited by GrimmTheTourist; 10-23-2020 at 11:40 AM. |
10-23-2020, 01:36 PM | #37 | |
Wheels vs water - Similar Threads | ||||
Water foam and wheels | bexline | Traxxas Crawlers | 2 | 05-28-2020 02:30 PM |
Hot Wheels Ford Raptor RC: Off Road Water Crossing | LAboy | Scale Videos! | 0 | 01-17-2016 10:02 AM |
water in my wheels. | dolphenwulf | Tires and Wheels | 32 | 09-15-2011 10:30 AM |
Drilling Holes In Wheels for Water Runs? | alexchen86 | Newbie General | 14 | 01-01-2010 12:56 AM |
WARNING! aluminum wheels+salt water= bad! | chino63 | Tires and Wheels | 16 | 06-17-2006 04:25 AM |
