Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Build Questions.
Old 10-21-2020, 04:25 PM   #1
Default Build Questions.
I am going to Build a Trail King Pro. My question is, how far into the build before you have to decide on a body? I know the chassis can be set up for different wheel bases.
Thanks for helping a new guy.
z381472 is offline   Reply With Quote
Old 10-21-2020, 04:31 PM   #2
Default Re: Build Questions.
I would pick the point where you have to decide on the length of the frame rails. Not that you cannot make adjustments once the build is complete, but it would just require tear down.
RCBrutus is offline   Reply With Quote
Old 10-22-2020, 07:07 AM   #3
It really depends on the build and what I am after.
For my Enduro C1 kit build, I knew I wanted a fairly scale body, so I did a bit of research to see what hard bodies I could possibly use. With that, when you are talking about chassis with a 12.3" WB, your choices are wide open, that is the defacto standard.
When you have a specific body in mind, you need to tailor the chassis to the build. For my TRX4 Tonka build, I had to shorten the WB down to accommodate the wheel wells on the body.
The long and the short of it is you can get anything to work, you just have to decided how much work you want to put into it.
Greatscott is offline   Reply With Quote
Old 10-22-2020, 07:37 AM   #4
I start with a body and build around it
So body should be first chassie second
ferp420 is offline   Reply With Quote
Old 10-22-2020, 07:59 AM   #5
Agreed. There are only so many options for both kit/body, depends on how scale you want it. A comp crawler or basher is not going to be wheelbase critical, but a scaler is. So that should decide what links/mounting points etc you are going to use and not vice versa.
Phildirt is offline   Reply With Quote
Old 10-24-2020, 11:00 AM   #6
Exactly what ferp420 said, I have many 1 off builds and always build around the body.
crawlhog is offline   Reply With Quote
Build Questions. - Similar Threads
A few pre-build questions (...and eventually a build thread) Shinook Axial Capra 12 06-14-2020 11:36 AM
want to do a build but have a few questions. kpla51 Axial SCX-10 9 09-14-2014 12:10 PM
new build questions skate General Scale Talk 1 09-15-2008 05:24 PM
My new build + questions Lorduss Tamiya TLT Crawlers 9 08-30-2007 03:35 PM
new build/first build lots of questions the kid Tamiya Clod Buster 4 01-31-2007 03:05 AM
