12-29-2020, 11:11 AM | #1 |
Newbie Join Date: Dec 2020 Location: Canada
| NiMh Battery for Axial SCX10 II
Whats a good nimh battery for the SCX10 II. 5/6 cell with IC3 connector. Quite vague as to requirements in the manual. A couple recommendations. Thanks |
12-29-2020, 11:26 AM | #2 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: NiMh Battery for Axial SCX10 II
Well for starters, don't waste your time with anything 5 cell, that would be uselessly low voltage. If you're adamant about staying NiMH then go for a minimum 6cell, 7 , 8 or even 9 (I don't know if they actually make those sizes, I quit thinking about NiMH in 2010) would be better. As far as capacity, I don't think capacity affects weight as much on Nickel batts as it does on LiPo so you might as well go for something 4000mAh or higher. But. Are you absolutely sure you don't want to use LiPo? Using NiMH in a new rig is roughly akin to putting a beat up old carbureted 350 into 2021 truck. It'll work, but wow that's old and crappy. Don't let the internet scare you into thinking LiPo's are ultra dangerous. Almost every case of LiPo fires I've ever encountered had some level of operator error. They are IMMENSELY better than NiMH batteries, IMMENSELY. Connectors is a whole other subject that I don't have time to delve into right now, but you should consider ditching the ic3 and going dean's or xt60. |
12-29-2020, 11:29 AM | #3 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
The best NiMH you can get is called a lipo
12-29-2020, 11:42 AM | #4 |
I'm purchasing lipos to run the rig outdoors. I'm storing them at my storage unit in lipo bags. But for testing/ running/ storing indoors at home, I'm going to get a nimh. If that makes any sense. As for connectors, I'm clueless at the moment. I'm enrolled at You Tube RC school. lol. Just want everything to plug and play while learning the ropes. Thanks. |
12-29-2020, 12:06 PM | #5 | |
| Re: NiMh Battery for Axial SCX10 II Quote:
Use XT60 connectors. They are the new standard. | |
12-29-2020, 12:23 PM | #6 | |
Back, many, many moons ago, lipo chemistry could get a little upset with the slightest bit of abuse, but today's lipo, bought from a reputable vendor like SMC, are safe you use just about anywhere. The same precautions you take with lipo are the same you take with NiMH, unplug them when not in use, store then properly, and treat them like the ocean when you are charging them. It over 10 years of using lipos, only once did I see one actually go nuclear, and that was because someone accidently shorted the lead wires via a heat sink. Never have I seen, or heard of a lipo getting energetically unhappy at rest. The issue with the Samsung Galaxy Note7's battery was due to is battery supplier trying to pad its profit by using old chemistry to make their packs, and is not typical of today's lipo packs. Last edited by Greatscott; 12-29-2020 at 12:27 PM. | |
12-29-2020, 02:08 PM | #7 | |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
12-29-2020, 02:19 PM | #8 |
Why not just leave a lipo on your bench like you do the nimh
12-29-2020, 03:16 PM | #9 |
| Re: NiMh Battery for Axial SCX10 II Well, let's just say I lean way over to the conservative side. Store my LiPos at storage voltage, in a LiPo bag, in a metal ammo can, on the basement concrete floor. Comes with old age, probably reflecting on the crazy things we did in our younger days and wondering how we managed to still be on the green side.
12-29-2020, 03:19 PM | #10 | |
12-30-2020, 12:17 PM | #11 |
| Re: NiMh Battery for Axial SCX10 II |
12-30-2020, 12:55 PM | #12 |
If you absolutely MUST go NiMH... Here are all the 5000mAh NiMH packs at RPP Hobby: https://www.rpphobby.com/category_s/...search=%205000 I personally would get a 6-cell, as the 7-cell adds weight up higher, and depending on the vehicle might not fit anyway. I'd personally get the Venom, as their UNI plug system has adaptors for nearly every connector type: https://www.rpphobby.com/product_p/vnr1548.htm |
12-30-2020, 01:28 PM | #13 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
I second the Venom batteries. I ran a few of them in my bashers I had before I got bit by the crawler bug, and they are a really good, powerful battery. I personally ran the 7-Cell 4200mah 8.4v hump pack, and it was pretty good for $42. It came with a bunch of different adapters so that’s also a plus. Sent from my iPad using Tapatalk |
12-30-2020, 02:48 PM | #14 |
Quarry Creeper Join Date: Feb 2018 Location: East otis
Venom has good customer service too. I had one that started failing on me that was almost 1 year old, and they replaced it no questions asked (other then a pic of it). Then i cut open the other ones i had and made 2 9 packs. Charged higher then a 3s lipo, as it wouldn't work in one of my 3 cell limited escs. This was a while ago, but I'd assume they'd still have a good warranty. Sent from my SM-G970U using Tapatalk |
12-30-2020, 03:20 PM | #15 |
Quarry Creeper Join Date: Mar 2009 Location: western ny
Don’t let everyone flame you into using lipos . A few years ago I was using lipos and had one blowup on me destroying my brand new associated rc10t . And have sworn them off ever since . Yes lipos are awesome for high speed stuff like racing or bashing but in a trail/crawling truck nimh is perfectly fine . I do agree with them to use Venom packs . I use 6 cell 3000 mah in my tf2s and I get an hour of good trail time .;
12-30-2020, 03:38 PM | #16 | |
12-30-2020, 04:02 PM | #17 |
Yes just get the correct connector and make sure to switch the esc pin over to the nimh settings .
12-30-2020, 04:05 PM | #18 | |
Yeah you can use the EC3 with the IC3 EDIT: you’ll lose the SMART function, but it will work. Sent from my iPad using Tapatalk | |
12-30-2020, 04:40 PM | #19 |
BTW - LiPos tend to get much more highly stressed in a high-speed vehicle, they dump faster and that can make them heat up. Frankly, that's why I don't worry about using them in my crawlers - it's less stressful, you can run lower "C" ratings - meaning cheaper packs... I always check the temp (just by feel, no big drama with a temp gun) on any new rig after a few minutes of running in case there's major binding in the drivetrain or shitty gearing choices were made during any modifications that DO make the pack run too hot. That's basically it when it comes to my worrying about LiPos! |
NiMh Battery for Axial SCX10 II - Similar Threads | ||||
axial YETI & NIMH battery | le varan | Axial Yeti | 29 | 04-10-2015 01:26 AM |
nimh battery ??? | The Violator | Electronics | 2 | 12-26-2011 07:15 PM |
Low cg battery plate nimh battery | aej_27 | Axial AX-10 Scorpion | 10 | 01-17-2011 08:44 AM |
