03-20-2021, 05:47 PM | #21 |
Newbie Join Date: Feb 2021 Location: Soddy Daisy
| Re: Newbie...Tell me about your electronics.
I'm a newbie and just installed a Mamba X esc and Castle Creations 2850 slate motor about a month th ago. The programmability of the Mamba is unbelievable and the power is there if you need it. I have my throttle curve set so that 70% of the trigger pull is only 20% power, then from there it ramps up hard.
03-21-2021, 11:02 PM | #22 |
Rock Stacker Join Date: Jun 2020 Location: Jakarta
Agree with most of the comment above, I am relatively new to this hobby too (almost 1 year) but I learned a lot through forum reading, youtube and trial and error, my suggestion for starter kit with my limited experience Holmes Hobby Crawlmaster Sport 550 12T Hobbywing 1080 esc PowerHD 23KG servo or comparable JX or SPT Radiolink RC6GS v2 3s LiPo (just like the other has said, skip the 2s) For brushless, if you want the sensorless route with good slow start control, go with Sidewinder 4, paired with outrunner motor like Holmes Revolver 1800kv-2200kv. Other option that I have tried is Tenshock RC906 1750kv, a 6 pole sensorless inrunner, paired with SW4 this motor is also smooth starter and cheap. You'll need BEC with SW4 due to its 5V/2A built in BEC If you go the sensored brushless route, Mamba X is hard to beat, with it's 8A BEC and 6s capable, this is the esc with rooms for future upgrade, the aux wire opens up great tunability, I used mine to control drag brake paired to the potentiometer switch on my RC6GS. The motor that I have tried with this esc and can highly recommend is Holmes Puller Pro, I used the 2700kv on my kit and very happy with it For servo, if you can afford it, Holmes SHV500 V3, this servo is what I finally ended with After my journey (of less than 1 year), I ended up with the following electronics on my main rig: Mamba X esc Holmes Puller Pro 2700kv (soon will be replaced with the 6 shooter) SHV500 V3 servo RC6GS v2 Tx/Rx kit, this kit comes with R7FG Rx that has a battery voltage reading port that I find very helpful My other rig, dedicated for trail run (with potential mud bath in it): Sidewinder 4 Castle waterproof BEC Tenshock RC906 1750kv JX CLS-12V7346, a copy of Holmes earlier servo |
03-22-2021, 04:22 AM | #23 | |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
| Re: Newbie...Tell me about your electronics. Quote:
Agreed!! I have my throttle curve set 70/30 and couldn’t be happier. Being new, programming the Mamba X is daunting but Holmes Hobbies step by step programming videos make it a snap. Also he explains the why of what the settings should be. Fantastic. | |
03-23-2021, 06:02 PM | #24 |
| Re: Newbie...Tell me about your electronics. The one thing he didn't mention in his video is that the brake curve also controls the reverse throttle curve. I set mine just like the forward throttle curve and now I can run 100% power reverse without it being sketchy fast lol
03-23-2021, 06:47 PM | #25 | |
I did not know that. On my to do list Thank you! | |
03-23-2021, 06:51 PM | #26 |
| Re: Newbie...Tell me about your electronics. |
03-26-2021, 07:38 AM | #27 | |
Newbie Join Date: Feb 2021 Location: East TN
Ive been working on mine off and on about 3 days now, and am getting fairly close to the end for the chassis part. My parts for the rest should be here next week. | |
03-26-2021, 07:58 AM | #28 |
Pebble Pounder Join Date: Feb 2019 Location: SIGNAL MOUNTAIN
rolltide386 , Looks like we live close to the same area. Where do you go crawling?
Newbie...Tell me about your electronics. - Similar Threads | ||||
Newbie electronics selection | SpudWrench | Newbie General | 12 | 10-18-2018 11:25 AM |
Newbie electronics problem | Phylodog | Newbie General | 8 | 02-02-2017 02:52 PM |
Electronics/led newbie | horvil15 | Newbie General | 7 | 08-23-2013 10:47 PM |
Newbie electronics ? | elkie | General Crawlers | 2 | 02-24-2006 05:27 PM |
RC newbie electronics questions | oIIIIIo | Newbie General | 2 | 01-26-2006 07:38 PM |
