Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Diff Output & Transmission Angles
Old 12-29-2021, 07:58 AM   #1
Default Diff Output & Transmission Angles
Still scratching my head on my first ground up build. I feel like every little step forward only brings about a lot of questions. I'm using a 2.low on a v3 GSpeed with TRX4 portals.
At rest (full droop?), how much should I worry about making the trans output and the diff output parallel. The 2.low outputs are quite high compared to the stock TRX4 single speed transmission outputs.
Sent from my SM-G973U1 using Tapatalk
swerv512 is offline   Reply With Quote
Old 12-29-2021, 10:39 AM   #2
Default Re: Diff Output & Transmission Angles
They dont need to be at the same elevation, just same angle compared to level
islandlife is offline   Reply With Quote
Old 12-29-2021, 10:49 AM   #3
That makes sense. My caster was all wacky trying to point the diff output up and towards the transmission output.
Diff Output & Transmission Angles - Similar Threads
Front diff output shaft rubbers? motopreserve Axial Yeti 2 12-08-2014 01:51 PM
transmission output question JDIRCC Axial SCX-10 8 07-13-2014 01:15 PM
Transmission output sheared lifttec999 Axial AX-10 Scorpion 2 08-05-2008 09:18 PM
Rear Transmission output glondark Axial AX-10 Scorpion 1 03-23-2008 04:52 PM
Where To Get The Transmission Output Yolks? patatron HPI Wheely King 1 05-04-2007 01:23 PM
