01-03-2022, 11:40 PM | #1 |
Newbie Join Date: Nov 2021 Location: Australia
| Battery plugs
Hi guys. Stupid question I know. But can I use any plug with any battery. I have one that came with an xt30 but want to swap it to deans? Thanks |
01-04-2022, 01:01 AM | #2 | |
Newbie Join Date: Dec 2021 Location: Rossland
| Re: Battery plugs Quote:
I found that the deans wore out too quick and in 1 case with my emaxx.....the heat created by the electrical draw melted the solder and it let loose Sent from my SM-G781W using Tapatalk | |
01-04-2022, 10:03 AM | #3 |
Quarry Creeper Join Date: Dec 2013 Location: The Garden State, North of I-80
| Re: Battery plugs
Pick a system that is common and available where you live and most people use in the area, and stick with it. Just a little soldering to change them out to whatever you want.
01-04-2022, 10:06 AM | #4 |
Rock Stacker Join Date: Mar 2009 Location: Abq
| Re: Battery plugs
Used Deans years ago, gonna standardize on XT60s now
01-04-2022, 06:06 PM | #5 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
| Re: Battery plugs
XT60 is where it's at, because you can get virtually every battery with one already installed. Deans go weak over time, and sometimes just randomly melt. For anything over 60A, I go with IC5, which are annoying as all get out, but they do work.
01-04-2022, 06:45 PM | #6 |
| Re: Battery plugs
you can use any conector on any battery just as long as both sides use the same style of plugs just becarefull a battery using a xt30 plug is a vary low amp battery that battery will likely flame on before you melt a deans plug |
01-04-2022, 10:06 PM | #7 |
Newbie Join Date: Dec 2021 Location: Renton
| Re: Battery plugs
Another recommendation for xt60. Large contact area and solid connections. But the answer is yes. Choose a style you like and swap it! |
Battery plugs - Similar Threads | ||||
battery plugs | Koldham | Electronics | 4 | 01-14-2014 12:15 PM |
Universal battery plugs | Rocklobst3r | Electronics | 19 | 05-01-2012 07:00 AM |
what plugs into what? | theloudone | Electronics | 4 | 02-18-2012 08:01 PM |
