10-14-2022, 07:58 PM | #1 |
Newbie Join Date: Dec 2010 Location: Canari Island
| Brake only with the rear axle
Hello, I have a modified XR10, how can I brake only with the rear axle? What radio do I need to do it? Thanks in advance Sorry for my bad English |
10-14-2022, 08:52 PM | #2 |
Pebble Pounder Join Date: Dec 2019 Location: East Tennessee
| Re: Brake only with the rear axle
Your English is perfectly clear. If I’m not mistaken, the XR10 is a motor-on-axle setup. I don’t have an MOA rig, so things are a bit different. What you’re looking for is a dig unit, and it looks like there are some electronic options for MOA rigs. You’d need an available channel on your receiver and transmitter to operate it. Just a quick search for MOA dig unit turns up some results.
10-14-2022, 09:48 PM | #3 |
Is your ESC a single ESC (1 ESC controlling 2 motors) or a dual ESC (2 ESCs controlling 2 motors)? If its a single ESC you can use a dig switch. RC4WD makes one (Rocker Dig II), I cant really think of any others. If you have a dual ESC you can use radio mixing to achieve dig. This is the best method. You will want a radio that can do mixing. I know most Spektrum radios can do this but most radios (that arent cheap RTR radios) should have mixing too, just check the manual before buying. |
10-15-2022, 06:36 AM | #4 |
Thanks Humboldt; I hadn’t considered the dual esc mixing option.
10-28-2022, 01:35 AM | #5 |
How strange, I have not received notification of your help. First thanks for your interest, if I have 2 motors and two ESCs, in the end I made the decision to use my classic Taranis aircraft radio, and I solved it. Last edited by AlexT; 10-28-2022 at 01:37 AM. |
Brake only with the rear axle - Similar Threads | ||||
Rear Light Bar with Strobes, Brake and Reverse | heyok | Vendors Electronics | 0 | 02-26-2020 09:25 AM |
Rear brake lights? | Silverblazer50 | Axial Yeti XL | 8 | 01-03-2016 10:54 PM |
Rear brake lights | Silverblazer50 | Axial Yeti XL | 1 | 06-17-2015 12:27 AM |
