03-19-2007, 08:08 PM | #1 |
Pebble Pounder Join Date: Jan 2007 Location: Gresham
| Electronic Setup Questions
I was not sure if this should have gone in the Noob section or here. So if the mods think it should be moved please do so. I am finishing up my 2.2 tlt build. And I wanted some advise before I spend the last of my "play" money. I am trying to decide on the battery type I should be getting, and if I should be getting a RX pack to go along with it. What I have Moped ESC Tower Pro mg995 servo Traxxas 3ch Tx and Rx I am not sure if the extra weight of the SC cells is worth it or the price, I can build 2 2/3A or 4/5A packs for the same price, and just change them when I am out at a GTG. But is there any else that the SC cells add besides run time. With the set up I have should I be getting a RX pack to run as well, or should I be ok. If so, do I just use 4-5 AA size cells? Thanks everyone, I have found almost all my answers just by searching but I wanted to see what everyone thought of this exact set up. Thanks Again TQ |
03-19-2007, 08:51 PM | #2 |
It would be a good idea to run an RX pack with that servo. The AA cells should take the load of one servo, shouldnt be more than 3-4 amps of load. For your batteries, that is up to you and your weight target. Can you shove subC's low on the front axle effectively? It can be done easily with 2/3A cells. Sounds like you are up to the task of some custom packs. |
03-19-2007, 09:35 PM | #3 |
Ok then a RX pack it is, should I do 4cells or 5? Custom is not a problem for me, that is why I got into crawling. If the performance side or the cells are equal besides run time, then 2/3 or 4/5 it is. I would rather put the weight lower then I can get the SC cells. Thanks |
03-19-2007, 09:42 PM | #4 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
I'd go 5 cell to ensure 6V to the servo... I use 5 cell 2/3A hump packs usually found in touring cars or gas stadium trucks - RC10GT, etc... I have 2.. A 1400 and an 1100... I've only used the 1100 but I get at least 2-3 hours out of it before it poops out for the day...
