04-03-2007, 11:52 PM | #1 |
Rock Stacker Join Date: Nov 2006 Location: Vancouver
| help!...TLT newbee question
i'm in the process of building my first TLT crawler and i have a problem mounting the stampede rear wheels in the stock TLT wheel axles. there were very small thread of the axles coming out when i mount the pede wheels. my problem now is that i cant screw the lock nut all the way to the nylon lock part of the bolt. the bolt keeps coming off everytime i run the truck. anyone who can help me on how i could fix this problem using the stock wheel axles? i know that the TG10 rear wheel axles will fix this problem but i cant find any of these parts in my LHS so my only option for the moment is to use the stock wheel axles. any info is greatly appreciated. thanks. |
04-04-2007, 12:21 AM | #2 | |
Quarry Creeper Join Date: Jan 2007 Location: Kansas City
04-04-2007, 01:02 AM | #3 | |
04-04-2007, 07:51 AM | #4 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
Go to homedepot and look for 1/2" barrel nuts they call them connectors or some sh!t. You'll need to drill the axle hole in the pede rim just a hair to get them to fit. The grind the barrel nuts so they are about a 1/16" from poking through the wheel. Use a dremel to slot the top for a flat head screw driver. That's it! Cost like $4. Might need to use blue locktite if they back off.
04-04-2007, 12:21 PM | #5 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
grind off the hexes on the side with no pin slot. take about half of it off.
04-04-2007, 12:37 PM | #6 |
RCC Addict Join Date: May 2005 Location: I live Here
weird i havent had any problems like that maybe cuz i bought front pedes ? ? ? get the widners cus if you do fit them then you will have problems with the tires rubbing on you steering or shocks |
04-04-2007, 03:06 PM | #7 |
You can also just partially drill out the hub of the wheel where the wheelnut goes to expose more threads. I think that's what most people do.
04-04-2007, 07:41 PM | #8 |
| got no more problem with the tires rubbing on the links and shocks cuz i already narrowed the wheel. have enough clearance now.
04-04-2007, 07:46 PM | #9 | |
alredy grind the wheels but still not enough. maybe i should grind more or try the one suggested by "obijuan" thanks guys for all the info. appreciate it very much. | |
04-04-2007, 08:49 PM | #10 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
there are some hpi stub shafts that you could use too, sorry cant remember the part number but if your local shop has em, just match em up to a stock. or go by size off tower.
